Author Topic: Edgy design efficient afterall  (Read 1423 times)
Offline Bezor
  • Puzzle Points 2
  • A Hairball?
« on: December 20, 2008, 06:11:00 PM »
Design
Edgy, Yet Still Aerodynamic
The Toyota FT-HS concept.
By PHIL PATTON
Published: December 19, 2008
WAYNE KOESTER was pleasantly surprised. Mr. Koester, who was a Ford aerodynamicist at the time, had been assigned to turn the popular boxy Fairlane design study that was introduced at the 2005 Detroit auto show, inspired by the woody station wagons of the 1940s, into the production Flex crossover. He had to produce a shape slippery enough to provide acceptable fuel mileage, and he feared the boxy show car would have to be radically revised.
Aerocorners include edges and bulges on the front of Toyota’s small city car, the iQ.
To his surprise, in hundreds of tests at Ford’s Wind Tunnel 8 southwest of Detroit the original edges produced less drag than curved substitutes, Mr. Koester said. In the bumper, headlights and hood, in fact, aerodynamics were improved by carefully designed edges.
Usually, aerodynamic shapes are rounded forms that slip through the air. But the wind tunnel is proving that counterintuitive, edgy shapes can reduce the drag coefficient and save fuel or battery power.
Many people associate aerodynamics with getting rid of edges and corners. But redoubled efforts to reduce drag have led engineers and designers to some surprising shapes. The discoveries offer both practical and aesthetic implications.
“Round is not always aero,” said J Mays, group vice president for design and chief creative officer of Ford. Some cars, including Porsches, have famously proved more aerodynamic when turned tail-first in the wind tunnel.
Mr. Koester’s box turned out to be a success. His team at Ford found that the box cut 0.02 off the Flex’s coefficient of drag, beating the competitors and providing a respectable 24 mile-a-gallon highway rating.
Toyota has begun using the term aerocorner for angular but aero shapes. The aerocorners include edges and bulges on the front of Toyota’s small city car, the iQ, its FT-HS concept and the next generation Prius hybrid. The idea, said Kevin Hunter, president of Toyota’s Calty Design Research studio in Newport Beach, Calif., is to smooth the flow of air down the sides of the car. The aerocorner pushes airflow out to reduce turbulence around the front-wheel housing, he explained.
The aerocorner is one of several aero elements Toyota has listed as keynotes of all future design strategy, as decreed by Toyota’s design chief, Wahei Hirai.
The other elements include forward-projecting front bumpers that send air around the car rather than under it, avoiding the drag of the messy underbody, still the aerodynamically crudest place on a car. Covering the underbody completely would be expensive and impractical, but some cars, including the Nissan GT-R and Ferrari California, cover parts of the underbody for smoother airflow.
The difference between the concept version of the Chevrolet Volt, the plug-in hybrid that General Motors first showed in 2007, and the production version shown in September, had to do with aerodynamics, said Bob Boniface, its chief designer.
“Aero is more about the rear of the car than the front,” said Freeman Thomas, director of strategic design at Ford, as he walked through displays at the recent Los Angeles auto show. Problem-causing drag behind the car stems not so much from frontal resistance as from swirling eddies of turbulent air at the rear. Designers now speak of managing airflow and having the air cleanly released at the back.
Efficiency is the key driver in aerodynamic design. “Remember, at highway speed about 60 percent of energy is used overcoming air resistance,” Mr. Hunter said. But aerodynamicists also have to worry about interior noise, stability and potentially dangerous lift at higher speeds.
The new shapes of aero can take small forms: a tiny tablike shape sits in front of the rear wheel of the Chevrolet Traverse crossover, and its roof rack has been lowered flush with the roof. The Chevrolet Volt lacks the wheel covers of earlier electrics and hybrids. “The wheels fill the wheel wells and we don’t need those,” Mr. Boniface said.
The Volt also offers a surprisingly sharp upright edge on its rear flanks, which makes for more controlled detachment of airflow from the side of the vehicle. A small, almost invisible edge on the bulging taillights of the new Mazda 3 is there to help snap the airflow neatly off the back of the car.
The new aero is visible in lower, wider grilles on many models. “We are trying to redefine the grille,” said Mr. Hunter of Toyota’s future designs. “It will be minimized quite a bit and given a different proportion. It is possible to have a thinner slit versus a big opening.”
The Chevrolet Volt's rear improves airflow.
Underbody of the Nissan GT-R.
Lower grilles take advantage of higher air pressure close to the ground. There is new emphasis across the auto industry on reducing cooling drag, from air pulled into the engine and radiator, Mr. Hunter said.
Some grilles are larger for aesthetic reasons rather than functional ones. “The grille is about symbolism,” Mr. Thomas said. Some small air slits are disguised as larger “mouths,” with closed-off portions.
Reduced drag does not necessarily mean increased beauty, however. The tall, hump-backed silhouette of the Prius is not exactly elegant, but Mr. Hirai, the Toyota design chief, has said that it will continue in the next-generation car. The grilles of the Ford Fiesta and Ford Ka are larger at the bottom for better airflow. Mr. Mays of Ford called that grille simply the “inverted trapezoid.” Mr. Thomas has named it the “acorn grille,” after its shape.
Most cars have two-part grilles. The top area of the grille has been the symbolic mouth — lower vents were visually disguised or de-emphasized. Now there is a change, according to Mr. Hunter. “There is a shift to emphasis on the lower grille,” he said.
“As designers, we are using that as an aesthetic advantage that we can leverage into other models,” Mr. Hunter said. “It is also a positive symbolic advantage for us, since fashion is still very important. It gives a good blend of fashion and function.”
The idealized low-drag shape, the earliest aerodynamics researchers decided, was the teardrop form: a rounded front and a long tapering tail, like a drop of water falling from a faucet. But by the 1930s, after research by Dr. Wunibald Kamm in Germany, it was widely understood that slicing off the back of the vehicle produced an aerodynamic result that was nearly as satisfactory and eminently more practical. (Experimental designs like the Oldsmobile Aerotech of 1987 demonstrated the aerodynamic long tail.)
When aerodynamics became a concern, with the arrival of cars like the Chrysler Airflow and Lincoln Zephyr in the 1930s, some designers feared it would make all cars look alike. Harley Earl, the design chief of G.M. at the time, said he thought 1940s streamlining was producing an inverted-bathtub look, as seen in the Chrysler Thunderbolt concept car or in postwar Hudsons.
But discoveries about the science of aero and new ideas about its art created fresh shapes. Earl developed big fenders and the tailfin to defeat the bathtub. In the 1990s, ovals were decorated with large traditional grilles and aerodynamically harmless creases.
Still, the wind tunnel continues to bring new discoveries. “Aero,” said Michael Simcoe, a veteran exterior designer at G.M., “remains a black art.”
Re: Edgy design efficient afterall
« Reply #1 on: December 21, 2008, 04:34:51 PM »
