Author Topic: Ford Falcon Ranchero Detail  (Read 10857 times)
Offline Bezor
  • Puzzle Points 2
  • A Hairball?
« on: October 17, 2008, 02:30:59 AM »
This Ford Falcon Ranchero has been in the family since new.  It’s always been a light duty truck, having been repainted once, and on it’s third engine.  Currently, it has a 291 cubic inch V-8 with single four-barrel carburetion. It has slightly larger cams, and intake and exhaust valves.  The exhaust is straight through with “cherry bombs”.  It fires straight away with a very mellow yet deep burble.
My purpose here is to show some detailing methods that I use on my other cars, since this is white, single stage paint, some pointers won’t apply to modern cars.   I didn’t detail the interior, and I only did a cursory clean up of the motor, which I do not  illustrate.
You can see we aren’t starting from complete dreck.    Mostly surface dirt, however, closer inspection of the pain revealed it needed more than a wash.  The paint is badly oxidized, has some stains and hard water spots.
First step is to get the surface dirt off:
I use two methods to wash cars.  First is the pressure washer with the yellow tank filled with Adams Car Wash (the one gallon white container that the pressure gun is pointing to)  Adams Car Wash is a relatively inexpensive cleaner that won’t strip wax, yet still has enough cleaning action to get most dirt, and some lite staining off.  The blue quart bottle is Optimum Car Wash.  Two capfuls of this will be put into the white 5 gallon bucket, while the red bucket gets plain water.  Having a wash bucket and a rinse bucket is called the “the two bucket method”.  Nearly all swirls, staring, and holograms are introduced to the paint because of poor wash technique, using the two bucket method substantially reduces the chances of dirt being reintroduced to the paint.
Pressured and firing away:  The Adams Car Wash is sprayed on.  Once the car is covered, let the soap dwell on the surface for about 5 minutes.
As the soap was left to work, I then started on the wheels using P21S Wheel Cleaner.  Application of this product for this car was over the top price wise, as I could have achieved the same effect with 409.
Agitate over the chrome with a wheel brush, and let dwell for 5 min.  It’s already been 5 min since we sprayed on the car wash, so be careful of the weather, particularly dry heat as you don’t want the car soap drying on the paint.
Hose the car off with an open nozzle on the hose.
This shows the lack of depth due to oxidation and mineral depostis from hard water.  The car has plenty of wax, yet the dead paint won’t allow for reflectivity.   The picture illustrated two passes on the hood with a Porter Cable CCS Orange pad and Mequires Quick Cut (medium cut)
This picture shows the Porter Cable dual action buffer with a mildly stiff orange pad and a blue microfiber towel.  Up to this point the pad was bogging down on the friction of the oxidation that was being removed.  Using the porter cable in this condition can get a bit tricky, as the polisher may take a bite and shoot off in any particular direction.  Working down through the oxidation takes time.
Using the blue masking tape illustrates the effects of the different levels of “cut” and what those levels produced.  To the far left of the blue tape is the washed hood with no polishing.  On the right is several passes of the Porter Cable with CCS Orange Pad and Mequires medium cut.  This small 2x3 foot section finally started to allow the pad to move over the surface of the paint without slowing the polisher's motor from the thick oxidation.
Moving from the Mequires and an orange pad, I switched to Menzerna Intensive Polish with a new orange pad.
After a few passes with Intensive Polish, I went with Menzerna PO85D also with a new orange CCS pad.
Comparing the left portion of the hood to the right the clarity, and reflectivity of the paint is coming through.  Friction on the pad is greatly reduced and work time for each pass was getting short and shorter.  Not shown here is the last step of putting on a sealant.  I chose Menzerna Full-Metalic- Jacket (FMJ) which is a super slick polymer (as opposed to carnauba wax).
Before the application of the FMJ as a final last step, we needed to attend to the wheels.  For this I used 1Z Metal Polish for the bumpers and rims.  Finishing off the tires I use Spraway Instant Shine.  Instant shine is rather like painting your tires from an aerosol can, the amount of reflectivity in the shine can be toned down to more OEM like look with less application of the product.
« Last Edit: October 18, 2008, 01:18:50 PM by Bezor »
Re: Ford Falcon Detail
« Reply #1 on: October 17, 2008, 02:47:54 AM »
Thanks for the contribution, Bezor.  You have been promoted to Feature Writer with all of its attendant privileges.
« Reply #2 on: October 17, 2008, 03:46:41 AM »
Nice work! It looks better than my 10-year-old Escort by a long shot.
Cool 'hose cam' shot, too!
Offline Bezor
  • Puzzle Points 2
  • A Hairball?
« Reply #3 on: October 17, 2008, 01:08:40 PM »
Thanks for the replies.
I'm not quite happy with it as I need to find a way to set the picutures within the article.  I thought of .pdf, and an uploaded link, but I don't think that would look to good either as when I read something, I want to be able to read it within the forum thread.
I still messing with the software, noobieness coming through.  For instance, I did not know the trick of reloading pictures as attachments once the first load is rejected.  Ultra hit me up on that little bit of info. :)
Ideas?
« Reply #4 on: October 17, 2008, 01:20:47 PM »
Ideas?
Send me the pictures via email formatted in the manner you choose and I will host them on the site so that you can inline them with the [img] function, Feature Writer.
 8)
« Reply #5 on: October 17, 2008, 02:02:33 PM »
Re: Ford Falcon Ranchero Detail
« Reply #6 on: October 18, 2008, 01:22:01 PM »
Bez,
We are going to make this a full Feature Article in the manner you see from  Otto's example.
http://www.autopuzzles.com/The%20Walter%20Hill%20Collection.htm
Be patient and you will be linked off of the front page with all the photos in their right place.
Offline Bezor
  • Puzzle Points 2
  • A Hairball?
« Reply #7 on: October 18, 2008, 07:35:55 PM »
OK., but I edited the pictures earlier today, and stuck them within the article and in the correct order.   It now presents the way I had wanted it to.  :)
« Reply #8 on: October 18, 2008, 10:30:59 PM »
I no see pics. :-\
Offline Bezor
  • Puzzle Points 2
  • A Hairball?
« Reply #9 on: October 19, 2008, 02:25:52 AM »
I no see pics. :-\
OK, then I'll send you the pics..... :)
« Reply #10 on: October 19, 2008, 07:17:05 AM »
I snagged them yesterday, when prepping to format the article.
Here it is! http://www.autopuzzles.com/Bezors%20Ranchero%20Detailing.htm
« Reply #11 on: October 19, 2008, 11:52:41 AM »
Sweet!
Offline Bezor
  • Puzzle Points 2
  • A Hairball?
« Reply #12 on: October 19, 2008, 03:56:32 PM »
Yeah for success.  Let's hear it for team work.....   :)
« Reply #13 on: October 19, 2008, 08:56:38 PM »
Welcome to the AutoPuzzles team.
 :yeah: :thumbsup:
