Author Topic: Solved - NEH 4139: Fiat-Abarth 1000 Spider Tubolare - 1961  (Read 1200 times)
Re: NEH 4139
« Reply #25 on: July 29, 2015, 12:14:59 PM »
Is it the Abarth 1000 SP that ran at 1969 Le Mans 24 hours?
It was built for Le Mans, but not in 1969.
Name is slightly different.. (Abarth 1000 ** *****  ********)
« Last Edit: July 30, 2015, 06:34:40 AM by Carnut »
Re: NEH 4139
« Reply #26 on: July 30, 2015, 05:44:41 AM »
Seems the Pro's are going to have to sort this one out then!
Re: NEH 4139
« Reply #27 on: July 30, 2015, 05:55:26 AM »
Abarth 1000 MC Sport Tubolare from 1962
Re: NEH 4139
« Reply #28 on: July 30, 2015, 06:09:29 AM »
This name will fit your clue (Abarth 1000 ** *****  ********) and I found this name in my index.
Checking the source, (Abarth Catalogue Raissonnee), it appears to be this one, the MC:
Googling that name, I think I found your source, but I still think the MC is different.
Re: NEH 4139
« Reply #29 on: July 30, 2015, 06:13:31 AM »
The puzzle car should be called 1000 Spider Sport, or Spider Tubolare, and had engines from 700 to 1000cc.
« Last Edit: July 30, 2015, 06:18:07 AM by Paul Jaray »
Re: NEH 4139
« Reply #30 on: July 30, 2015, 06:39:09 AM »
That is the name I was looking for, yes.  It was For Sale and that's how it was described and was built for Le Mans.  You'd think the seller would know what it was..
I dug a bit of information out about the car built for Le Mans which is reproduced below; I assume this is the same car but a lot of these names have been attributed down the years rather than by Abarth when the car was first made, I think.  You'll note that in neither article do they actually mention a name for the car!
You seem to be right that the MC Sport Tubolare is a different car so I'll try to give it the correct name in the heading!
« Last Edit: July 30, 2015, 06:53:37 AM by Carnut »
Re: NEH 4139
« Reply #31 on: July 30, 2015, 06:49:14 AM »
I think this is probably the same car but with some later body modifications.
Here's the original puzzle picture:
