Author Topic: Solved: gte4289_99 -- 1920 AV Bi-car  (Read 617 times)
Offline gte4289
  • Puzzle Points 882
« on: January 14, 2019, 02:34:13 PM »
Please identify this car for a point:
Offline Lavrakas
  • Puzzle Points 89
  • YearsYearsYearsYearsYearsYears
Re: gte4289_99
« Reply #1 on: January 18, 2019, 04:54:17 PM »
Is this an AV Monocar of about 1919, or is that too obvious?
The more I consider the nature of speed, the more mysterious I find it.
Offline gte4289
  • Puzzle Points 882
Re: gte4289_99
« Reply #2 on: January 18, 2019, 07:04:52 PM »
Correct make, wrong model. 24-hour lock for you to identify the correct model.
Offline Lavrakas
  • Puzzle Points 89
Re: gte4289_99
« Reply #3 on: January 19, 2019, 04:46:48 AM »
The Runabout. You could just about get two people in it.
Offline gte4289
  • Puzzle Points 882
Re: gte4289_99
« Reply #4 on: January 20, 2019, 07:02:19 PM »
This is neither the Monocar of 1919, nor the Runabout of 1921. Due to my late reply, still locked for you to identify the correct model.
Offline Lavrakas
  • Puzzle Points 89
Re: gte4289_99
« Reply #5 on: January 21, 2019, 05:34:02 AM »
By elimination, it would have to be the B-Car with the tandem seat covered over.
Offline Lavrakas
  • Puzzle Points 89
Re: gte4289_99
« Reply #6 on: January 21, 2019, 11:28:14 AM »
I meant to say Bi-Car!
Offline gte4289
  • Puzzle Points 882
Re: gte4289_99
« Reply #7 on: January 21, 2019, 12:16:00 PM »
The point is yours! I should clarify, however...
The three models produced were:
  • Monocar (production beginning 1919; 30" wide; single-seater)
  • Bi-car (production beginning 1920; 36" wide; described as a two-seater with passenger(s) "behind the driver")
  • Runabout (production beginning 1921; 42" wide; described as a two-seater with "side by side" seating)
As the images below indicate, seating in the "A.V. Bi-car" or "Two-Seater" was not tandem. The wider passenger's seat was located to the side of, yet slightly behind the driver's seat. I am also including an image which is said to depict the "Runabout." While there are notable differences between the Bi-car and Runabout, the seating arrangement actually appears to be similar, if not identical.
« Last Edit: January 21, 2019, 12:35:01 PM by gte4289 »
