Author Topic: Solved -PJ673- Forest car by Gérard Forest, 1978  (Read 291 times)
« on: July 15, 2015, 04:12:03 AM »
Here you are a car that I found in my HD but I'm not sure of what it is.
The name is clearly readable but I'm not convinced.
1 point for that name plus some more info about it.
  • Puzzle Points 2352
Re: PJ - 673
« Reply #1 on: July 15, 2015, 04:31:53 AM »
The name on the radiator is Forest, but it is a modern recreation, as you can see: it has ventilated disc brakes at the front axle. It was built in 1978 and has a 850 cc Wisconsin engine of 18 hp.
« Last Edit: July 15, 2015, 04:38:51 AM by Wendax »
Re: PJ - 673
« Reply #2 on: July 15, 2015, 04:43:39 AM »
That was quick!
Do you know who built it and where?
No need to lock it, it's your point anyway.
Re: PJ - 673
« Reply #3 on: July 15, 2015, 04:51:01 AM »
It was built by Gérard Forest.
Re: PJ - 673
« Reply #4 on: July 15, 2015, 05:12:18 AM »
Perfect!
With your info I just found the same article online!
I guess there's no need to loose so much time trying to look for more info all by yourself when you can rely on a team of Autopuzzlers!
Well done Wendax, another point for you!
