Author Topic: GTC #128 SOLVED: Rootster by Jim Root  (Read 453 times)
Offline DHoffmann
  • Country: nz
  • Puzzle Points 87
  • On holiday
« on: June 02, 2015, 06:30:30 AM »
This lightweight machine begins straight in the experts!
Recognize it? Then let me know!
Offline richard cuyler
  • Puzzle Points 78
Re: GTC #128
« Reply #1 on: June 02, 2015, 07:59:31 AM »
"Ooooo, Butch, you're so strong!"
"I know. Do you fancy me?".
"Only if I never have to be seen with you in your car!"
Online kwgibbs
  • Puzzle Points 428
Re: GTC #128
« Reply #2 on: June 02, 2015, 09:38:39 AM »
was this a home-built called the rooster?
Offline DHoffmann
  • Country: nz
  • Puzzle Points 87
  • On holiday
Re: GTC #128
« Reply #3 on: June 02, 2015, 09:42:42 AM »
She'd be somewhat less impressed if she knew the actual weight of the car.  ;D
Yes homebuilt and oh so tantalisingly close with the name, but there's an important distinction to the name relating to the creator so I'll hold this one for you to figure that one out.
Online kwgibbs
  • Puzzle Points 428
Re: GTC #128
« Reply #4 on: June 02, 2015, 10:00:20 AM »
the information I have found is,Jim Root,was a automotive engineer from Kansas city,has built a car that can accelerate to 96 kilometers per hour,due to its five horsepower.It,s a cross between a car and a motorcycle.The wheels were taken from the motorcycle.The body is made of plastic.In the tiny compartment behind theseat is the engine. Jim Root calls his car "Rooster". Weighing only 90 kg,its cruising speed is 56 km/h.
Offline DHoffmann
  • Country: nz
  • Puzzle Points 87
  • On holiday
Re: GTC #128
« Reply #5 on: June 02, 2015, 10:33:05 AM »
That is certainly more than enough information to warrant the point!
The name I was looking for, and you may have misread somewhere, is 'Rootster' incorporating his surname fully, but clearly all the requisite info is there!
Online kwgibbs
  • Puzzle Points 428
Re: GTC #128 SOLVED: Rootster by Jim Root
« Reply #6 on: June 02, 2015, 10:37:14 AM »
yes, your right it should have been Rootster instead of rooster,but thanks for the point.
