Author Topic: Solved TGF-313: NKL-26 Aerosan with Shvetsov M11G engine  (Read 5288 times)
« on: December 24, 2013, 12:57:18 PM »
Can you identify this vehicle?  I need its name, its builders and its engine.
« Last Edit: January 02, 2014, 01:27:53 PM by targhediferro »
Re: TGF-313
« Reply #1 on: January 02, 2014, 08:46:30 AM »
No interest among Experts...so, up.
Re: TGF-313
« Reply #2 on: January 02, 2014, 11:00:45 AM »
This is an NKL-26 Aerosan by Trumpeter.  It is powered by an M-11G aircooled aircraft engine (5 cylinder radial).
Re: TGF-313
« Reply #3 on: January 02, 2014, 12:00:39 PM »
Not that according to my source.
Offline Hiawatha
  • Puzzle Points 524
Re: TGF-313
« Reply #4 on: January 02, 2014, 12:58:29 PM »
Not here to steal a point...Nearly everything said in the answer is correct, The vehicle is indeed a NKL 26 on wheels rather than the more usual skis.It was powered by a Shvetsov M11 G engine. The picture appears to be from a russian construction kit by AMG.
Trumpeter is the name of another kit manufacturer.
Re: TGF-313
« Reply #5 on: January 02, 2014, 01:14:12 PM »
Well, I have to check my source, because I had another name but now I suppose both of you are right;  actually, Sixtee5cuda was so near the correct answer that I would have locked it even if Trumpeter shouldn't be correct, so I'll give him the point if I will check that my source is wrong.  Sorry Hiawatha.
Re: TGF-313
« Reply #6 on: January 02, 2014, 01:26:58 PM »
Ok, my source has two pictures with crossed captions!  It's indeed a NKL 26 Aerosan with Shvetsov M11G engine.  A point for Sixtee5cuda.
