Author Topic: Solved - NEH 3785: LECo Mk1 MG Special - 1951  (Read 872 times)
« on: November 14, 2014, 09:09:44 AM »
« Last Edit: December 15, 2014, 04:56:17 AM by Carnut »
Re: NEH 3785
« Reply #1 on: November 28, 2014, 05:30:56 AM »
Offline richard cuyler
  • Puzzle Points 78
Re: NEH 3785
« Reply #2 on: November 30, 2014, 08:05:40 AM »
British?
Re: NEH 3785
« Reply #3 on: November 30, 2014, 11:36:25 AM »
Re: NEH 3785
« Reply #4 on: December 12, 2014, 05:13:15 AM »
Won't last more than a few minutes with the Professionals...
Online nicanary
  • Puzzle Points 632
Re: NEH 3785
« Reply #5 on: December 12, 2014, 05:14:27 AM »
Surely not a Cooper-Bristol?
Re: NEH 3785
« Reply #6 on: December 12, 2014, 05:15:39 AM »
Absolutely right!  It's not...
Online nicanary
  • Puzzle Points 632
Re: NEH 3785
« Reply #7 on: December 12, 2014, 05:19:57 AM »
But it's Bristol engined?
  • Puzzle Points 413
Re: NEH 3785
« Reply #8 on: December 12, 2014, 06:20:34 AM »
Can't say I remember this one, but it looks MG (XPAG) engined to me.
Online nicanary
  • Puzzle Points 632
Re: NEH 3785
« Reply #9 on: December 12, 2014, 06:34:24 AM »
Unfortunately, the front mudguard hides the central exhaust system, and I can't see if it's one pipe, or a siamesed pair. I rather assumed it was a 6-cylinder engine.
I'm baffled. It looks familiar, but I can't think where to look.
Re: NEH 3785
« Reply #10 on: December 12, 2014, 07:37:16 AM »
No, it's not Bristol-engine nicanary.
Allan is right in that it has an MG engine, quite probably an XPAG although my information didn't say exactly.
Online nicanary
  • Puzzle Points 632
Re: NEH 3785
« Reply #11 on: December 13, 2014, 05:51:59 AM »
This is, I assume, a one-off homebuilt?
Re: NEH 3785
« Reply #12 on: December 13, 2014, 12:19:17 PM »
Yes!
Online pnegyesi
  • Puzzle Points 1177
Re: NEH 3785
« Reply #13 on: December 13, 2014, 01:52:11 PM »
Ford power?
Re: NEH 3785
« Reply #14 on: December 13, 2014, 04:00:45 PM »
Ford power?
No, we've already estalished tha it's MG-powered (see Reply #10).
Online pnegyesi
Re: NEH 3785
« Reply #15 on: December 13, 2014, 04:19:30 PM »
sorry
Offline serra
  • Puzzle Points 265
Re: NEH 3785
« Reply #16 on: December 14, 2014, 06:05:45 PM »
I was sure i had seen this before, It is the LEco MG MKI and as MKII by Liss Engineering Company with Fred Sturges and Peter Tompkins built around 1952. It used a  1292-cc four-cylinder engine and four-speed gearbox from a 1937 MG TA. Suspension used transverse leaf springs, front and rear. The Mk 1’s rack-and-pinion steering gear came from a Morris Minor. Chassis tubes for the Mk 1 were sourced from Connaught Engineering. Aluminum bodywork evolved with a Vanwall nose cone.
This is the photo I had from the other LEco Puzzle http://www.autopuzzles.com/forum/index.php?topic=29358.msg347858#msg347858
« Last Edit: December 14, 2014, 06:14:33 PM by serra »
Re: NEH 3785
« Reply #17 on: December 14, 2014, 06:59:20 PM »
Yes.  I thought you would know it since you got the MkII..
