Author Topic: GTC #39 SOLVED: Fiat Abarth 6000 T-140 V12 Prototype  (Read 2277 times)
Offline DHoffmann
  • Country: nz
  • Puzzle Points 87
  • On holiday
« on: September 15, 2008, 09:21:58 AM »
Who knows what this is?
1 point for the correct answer.
Good luck!
« Last Edit: April 18, 2015, 02:24:25 AM by DHoffmann »
Offline DHoffmann
  • Country: nz
  • Puzzle Points 87
  • On holiday
Re: GTC #39
« Reply #1 on: September 20, 2008, 03:03:12 PM »
  • Puzzle Points 658
Re: GTC #39
« Reply #2 on: September 20, 2008, 05:52:22 PM »
French?
Re: GTC #39
« Reply #3 on: September 20, 2008, 07:23:19 PM »
Fiat Abarth 6000 T-140 from 1967
Offline DHoffmann
  • Country: nz
  • Puzzle Points 87
  • On holiday
Re: GTC #39
« Reply #4 on: September 20, 2008, 09:52:40 PM »
Correct... Although sometimes I wish you weren't correct.  ;D
Seriously though, I'm impressed and thankful. I was not aware of another exterior shot available!
Re: GTC #39 SOLVED: Fiat Abarth 6000 T-140 V12 Prototype
« Reply #5 on: September 21, 2008, 03:03:54 AM »
By the looks of it, I suppose interior shots are nigh well impossible to find.  ;)
« Reply #6 on: December 27, 2010, 08:04:54 AM »
Came across some additional data and photos:
Designers: Mario Colucci, Luchino Fochi (engine)
Chassis: Tubular, fiberglass body
Engine: 12 cylinders Abarth opened at 120 °, type 240A, rear center position
Displacement: 5982.84 cm 3 (92 x 75)
Distribution: 2 ACT
Power: 600 hp estimated at 6,800 rpm
Food: 4 Weber 40 IDA carburetors 3CI
Transmission: 5 speed
Brakes: 4-wheel drives in
Tires: 6.00 M x 15 x15 and 6.00/12.00
Length: 4100 mm
Width: 1850 mm
Height: 1030 mm
Wheelbase: 2450 mm
Channels: 1470 mm front and rear
Weight: 1110 kg
Solved - NEH 3549: Abarth T140 6000 - 1967
« Reply #7 on: June 11, 2014, 07:34:47 AM »
« Last Edit: June 11, 2014, 07:44:56 AM by Carnut »
Re: NEH 3549
« Reply #8 on: June 18, 2014, 05:20:44 AM »
Offline Iluvatar
  • Puzzle Points 245
    • www.automobileitaliana.it
Re: NEH 3549
« Reply #9 on: June 18, 2014, 06:02:16 AM »
Abarth T140, only a scale model.
Facebook automobileitaliana
Instagram @autoitaliana
Offline Iluvatar
  • Puzzle Points 245
Re: NEH 3549
« Reply #10 on: June 18, 2014, 06:10:23 AM »
this project is from 1967, and should have been a V12 6000cc engine.
Re: NEH 3549
« Reply #11 on: June 18, 2014, 06:12:47 AM »
Yes, that's the one.
It never got beyond the model scale, though I thought (judging only by these pictures!) that it was a full-size clay model?:
Offline Iluvatar
  • Puzzle Points 245
Re: Solved - NEH 3549: Abarth T140 6000 - 1967
« Reply #12 on: June 18, 2014, 08:44:48 AM »
You are right, there was a full size model...  ;)
« Reply #13 on: June 19, 2014, 03:52:59 AM »
Merged
