Author Topic: Solved - NEH 2363: Patterson-Brydon MG TC Special - 1948  (Read 1186 times)
« on: January 09, 2013, 06:04:18 AM »
What's this car, what is it based on, who built it and when?  For 1 point:
« Last Edit: January 09, 2013, 06:09:52 AM by Carnut »
Re: NEH 2363
« Reply #1 on: January 16, 2013, 05:01:55 AM »
Offline Craig Gillingham
  • Country: au
  • Puzzle Points 236
Re: NEH 2363
« Reply #2 on: January 16, 2013, 06:52:52 AM »
This is an Australian car, called the 'Patterson-Brydon MG TC Special'. The VHRR website says this about the car;
"The Patterson-Brydon MG TC Special was built during the latter part of 1948, by Bill Patterson, Reg Nutt and Doug Whiteford. The racing body was designed as a two seater and was built by Bob Baker. It was painted green and was panelled in light gauge aluminium over a welded frame of light angle iron. The panels were attached by quick release Dzus fasteners. The highly developed engine of the special was fully balanced, fitted with larger valves and a Marshall supercharger. The ignition was provided by a Scintilla Vertex NV4 magneto and the fuel was fed to the carburettor by air pressure in the tank, by using a hand pump in the cockpit. The special pressurised cooling system used a modified Ford V8 radiator core."
Re: NEH 2363
« Reply #3 on: January 16, 2013, 07:28:39 AM »
Quite so!
Well done and thanks for the very full answer.
« Last Edit: January 16, 2013, 07:31:24 AM by Carnut »
  • Country: au
  • Puzzle Points 236
Re: Solved - NEH 2363: Patterson-Brydon MG TC Special - 1948
« Reply #4 on: January 16, 2013, 07:32:07 AM »
I saw it in the Rookie section last week, and I was ready and waiting to pounce.
Offline el_monty
  • Puzzle Points 309
« Reply #5 on: June 28, 2019, 06:47:37 AM »
Puzzle image not visible
