Author Topic: Solved - NEH 2488: Renault Projet H - 1967  (Read 403 times)
« on: February 19, 2013, 07:18:12 AM »
Re: NEH 2488
« Reply #1 on: February 26, 2013, 05:02:28 AM »
Re: NEH 2488
« Reply #2 on: February 26, 2013, 05:26:16 AM »
Renault project H, about 1970
Re: NEH 2488
« Reply #3 on: February 26, 2013, 05:49:40 AM »
It's a Renault project, but I have as something different from Projet H and from a different year.
Locked for you to have another look.
Re: NEH 2488
« Reply #4 on: February 26, 2013, 08:29:00 AM »
You're right about the year, because the project began in 1966 and was abandoned in 1970.
I actually am quite sure this is the second prototype of project H (also named 120); la Regie Renault wanted to realize a 8v engines saloon to put at the top of the range of French production, as, after the end of Poissy's 8v and Facel-Vega quitting, there was no French engine bigger than 4 cylinders.
The project was in Gaston Juchet's hands, and designers as Beligoud, Dumolard, Mormand, were interested.
The first prototype had a different from grille (from Ghia prototype 114), and it was possible to open rear window; in the second the dashboard too was modified. Somewhere these prototypes are called Super 16.
From the third car derived the Fuego's project.
Re: NEH 2488
« Reply #5 on: February 26, 2013, 09:42:44 AM »
Yes, I think you're right.  It's just something my computer had inserted into the text I think..
Here are a couple more views, although the side view seems to me to be of a different car:
