Author Topic: SOLVED: del78 no.190 by cmetisse: Jeanneau Microcar  (Read 423 times)
Offline del78
  • Puzzle Points 269
  • SiD
« on: June 23, 2013, 06:36:31 PM »
what is this for a point
Offline del78
  • Puzzle Points 269
  • SiD
Re: SOLVED: del78 no.190 by cmetisse: Jeanneau Microcar
« Reply #1 on: July 09, 2013, 08:10:17 PM »
experts time
Offline kwgibbs
  • Puzzle Points 428
« Reply #2 on: July 09, 2013, 08:11:40 PM »
Rolt,possibly?
Offline del78
  • Puzzle Points 269
  • SiD
« Reply #3 on: July 09, 2013, 08:50:44 PM »
not the name I have
Offline kwgibbs
  • Puzzle Points 428
« Reply #4 on: July 09, 2013, 11:24:16 PM »
Axiam?
Offline luisps
  • Puzzle Points 407
« Reply #5 on: July 10, 2013, 02:45:32 AM »
MICROCAR RJ French voiturette made between 1985-86
Offline cmetisse
  • Puzzle Points 140
« Reply #6 on: July 10, 2013, 02:49:18 AM »
It is a Microcar from the "L-GL-GLX" generation.
More precisely, it is the facelift version, with a longer nose and flush-mounted headlights (borrowed from a Fiat Panda). The first gen had the trim name before the engine number (L 50, GL 50, GLD 50), these versions reverted it.
I bet it is the 300 GL, with the bigger 273 cc Yanmar L60 (replacing the tiny 199 cc L40 used on the LD/GLD 50), as the picture seems to be taken at the Jeanneau Microcar stand at the 1986 Paris Motorshow.
One year later, a twin-cylinder 600 GL, using the "monster" Ruggerini 654 cc became available with this body, as well as a restyled 125 GL. Another big change was the fitting of a brand new braking system, removing the weird-as-hell Luchier "annulus discs" to more classical drums.
« Reply #7 on: August 02, 2013, 01:26:59 PM »
Bump!
Offline del78
  • Puzzle Points 269
  • SiD
« Reply #8 on: August 04, 2013, 06:53:24 PM »
point goes to cmetisse as he mentioned the name Jeanneau, same as in my source
  • Puzzle Points 2351
« Reply #9 on: August 05, 2013, 03:22:47 AM »
But the name of the car is not Jeanneau Microcar, but - as cmetisse stated - Microcar 300 GL. The Jeanneau name is not part of the vehicle's name. So you should change the header.
Offline cmetisse
  • Puzzle Points 140
« Reply #10 on: August 05, 2013, 12:56:47 PM »
Yes, the confusion is coming from the Microcar brochures, that used a "Microcar by Jeanneau" motto from 1980 to 1988. They changed it to a "Microcar Automobiles" naming on the last brochures of the "L-GL-GLX" range, and then of course on the Spid for the 89 MY.
Here is some samples of brochures to give a better explanation of the confusing Microcar nameplates :
Offline cmetisse
  • Puzzle Points 140
« Reply #11 on: August 05, 2013, 12:58:08 PM »
The facelifted 300 GL is here :
Offline cmetisse
  • Puzzle Points 140
« Reply #12 on: August 05, 2013, 12:59:33 PM »
And, as I said, the second generation of Microcar was launched in fall 1984, with trim level before engine capacity names. Here is an example, for the 86 MY range :
