Author Topic: Solved TGF-211: F.N. Tricar T-3 (or T-8), 1947  (Read 410 times)
« on: October 01, 2013, 10:42:51 AM »
Make, model and year are requested for a point.  I hope it is not a repost ( I haven't found it)
« Last Edit: October 02, 2013, 08:57:43 AM by targhediferro »
Offline Hiawatha
  • Puzzle Points 528
Re: TGF-211
« Reply #1 on: October 01, 2013, 11:04:06 AM »
1947 FN from Belgium?
Re: TGF-211
« Reply #2 on: October 01, 2013, 11:48:09 AM »
That's right. I have a model description (I suppose the power). Locked for you.
Offline Hiawatha
  • Puzzle Points 528
Re: TGF-211
« Reply #3 on: October 01, 2013, 01:43:32 PM »
Only name I could find is Tricar...
Re: TGF-211
« Reply #4 on: October 01, 2013, 03:09:41 PM »
Actually the model designations were two, one for the short chassis, the other one for longer one.
Offline DeAutogids
  • Puzzle Points 204
  • This text is just for you!
    • dAuto.nl
Re: TGF-211
« Reply #5 on: October 01, 2013, 03:53:26 PM »
Is it still locked?
Re: TGF-211
« Reply #6 on: October 01, 2013, 04:10:33 PM »
Yes, Hiawatha hasn't answered yet.
Offline Hiawatha
  • Puzzle Points 528
Re: TGF-211
« Reply #7 on: October 02, 2013, 01:55:45 AM »
M 12?
By the way, it's a repost...
Re: TGF-211
« Reply #8 on: October 02, 2013, 03:37:25 AM »
Not M12...I know it is a repost because Wendax sent me a PM...I did not fount it because I searched for F.N. instead of FN.  Now I told Wendax that I found unfair to remove the quiz after you had given the correct answer, but if you can't find the correct model name I will have to remove it.
Offline Hiawatha
  • Puzzle Points 528
Re: TGF-211
« Reply #9 on: October 02, 2013, 08:40:48 AM »
I spent ages on this apparently easy puzzle..I found the same picture you used but  no mention of a model name.
Only thing I have read is that it was based on the military tricar. I will try T3. If it's wrong you can unlock/ delete.
Re: TGF-211
« Reply #10 on: October 02, 2013, 08:57:03 AM »
It is right or so I may presume. Actually there where two model, T3 (short chassis) and T8 (long chassis).  As it is impossible to understand which the pictured one is, I'll get if as correctly solved.
A point for you.
Now the puzzle may be merged.
Offline DeAutogids
  • Puzzle Points 204
    • dAuto.nl
Re: Solved TGF-211: F.N. Tricar T-3 (or T-8), 1947
« Reply #11 on: October 02, 2013, 09:01:19 AM »
This clearly is a short chassis. It is actually shown in Brussels in Autoworld.
Offline Hiawatha
  • Puzzle Points 528
« Reply #12 on: October 02, 2013, 09:16:46 AM »
Where you took a nice picture!
Offline DeAutogids
  • Puzzle Points 204
    • dAuto.nl
« Reply #13 on: October 02, 2013, 09:57:20 AM »
This one?
Offline Hiawatha
  • Puzzle Points 528
« Reply #14 on: October 02, 2013, 10:20:54 AM »
Yes,indeed..
Offline DeAutogids
  • Puzzle Points 204
    • dAuto.nl
« Reply #15 on: October 02, 2013, 10:55:32 AM »
I think the T3 and T8 are motorcycle based vehicles, after some research. If only as this vehicle is from 1947 and the T3 and T8 was made up to 1940.
