Author Topic: Solved - NEH 2659: Kapi Lujo Sedan - 1955  (Read 473 times)
« on: May 21, 2013, 07:06:09 AM »
Re: NEH 2659
« Reply #1 on: May 28, 2013, 05:27:12 AM »
Offline luisps
  • Puzzle Points 407
Re: NEH 2659
« Reply #2 on: May 28, 2013, 02:21:53 PM »
Spanish KAPI, presented at Barcelona's Feria de Muestras in 1955. This is the only known surviving unit in the area of Benissa close to Alicante.
Re: NEH 2659
« Reply #3 on: May 28, 2013, 02:39:58 PM »
Kapi is correct, yes.
I believe it has a model name as well though (that's if the name I have is a model name..!)
Locked for you to come up with it for the point (or tell me what it is if not the model name)
Offline luisps
  • Puzzle Points 407
Re: NEH 2659
« Reply #4 on: May 28, 2013, 06:07:17 PM »
I was expecting your request, but I've lived out that part of the answer as there is a big discussion about the model's name to be applied to that car. Not an original picture of it from 1955 contains a name. In that year and in the same news paper, and same month (April) but with 8 days of difference appears a draft of a KAPI car with some similarity to that one with two different names: LUJO and SEDAN, in the second case also with the specification SEDAN 175 4T4R, that means 4 stroke engine (Fita AMC) 4 wheels and 175 c.c. In the same 2nd advertisement on says that it will be presented in the next "Feria de Barcelona" in June 1955.
Recently I had access to some documentation in hands of the descendants of he creator of KAPI (Capitán Federico Saldaña). The best one is a hand written "Sales book" (without pictures) of 1953-1955 in which at the end of 1955 appears 6 units of the model SEDAN. Also I've seen a picture with some authorities visiting the booth of KAPI in the "Feria" in it is possible to recognize part of the top of this car, but the picture only has, in its back, the reference "Feria Muestras 1955", no models name. So I consider that SEDAN is its correct model name.
Re: NEH 2659
« Reply #5 on: May 28, 2013, 06:39:34 PM »
That's enough for the point!
Lujo was the name I had which you have mentioned but I don't know if that is a correct model name (or Spanish for 'Sedan' for that matter!)
Re: Solved - NEH 2659: Kapi Lujo Sedan - 1955
« Reply #6 on: May 29, 2013, 05:34:03 AM »
Another picture of this car:
« Reply #7 on: May 30, 2013, 04:04:56 AM »
apparently it hanged too long in the wardrobe...
