Author Topic: Q506 - solved - 1989 Cheetah  (Read 2521 times)
Offline gilescooperuk
  • Puzzle Points 92
  • Croft
    • www.gilescooper.co.uk
Re: NEH 2674
« Reply #25 on: May 30, 2013, 04:54:46 PM »
Well I can tell the base car is an MX-5, the question is what make and why would you do that to a mazda?
Cars and er other photos
  • Puzzle Points 650
Re: NEH 2674
« Reply #26 on: May 30, 2013, 06:49:25 PM »
If it IS based on an MX5 then it is about 4/5th scale! Is it a commercial kit-car or a one-off ?
Re: NEH 2674
« Reply #27 on: May 31, 2013, 06:14:39 AM »
It's not MX5 based.
Re: NEH 2674
« Reply #28 on: May 31, 2013, 06:16:14 AM »
Is this a smaller than full size replica, eg 3/4 full size?
Crikey, I don't think I can answer that!
It's not the same dimensions as an E-type but not sure in what way it differs.
It's not smaller than an E-Type!
Offline fyreline
  • Puzzle Points 261
  • Livin' the Dream . . .
Re: NEH 2674
« Reply #29 on: May 31, 2013, 01:11:39 PM »
I certainly agree that it takes the prize for the ugliest E-type ever. It's actually from Down Under (New Zealand, to be exact) and it was built over 1990-1991 by a fellow called Grant Loch. He named it the Cheetah, and it was built on a Holden HQ base.
Yikes.
"You are entitled to your own opinion, but you are NOT entitled to your own facts"
Re: NEH 2674
« Reply #30 on: June 01, 2013, 07:16:50 PM »
Yikes.
Yes, the Cheetah it is, based on the Holden Headquarters..
Apparently 9 of these were made!
Offline dzima1985
  • Country: by
  • Puzzle Points 376
Re: Solved - NEH 2674: Holden-based Cheetah
« Reply #31 on: June 02, 2013, 03:01:51 AM »
another view:
Offline fyreline
  • Puzzle Points 261
« Reply #32 on: June 02, 2013, 09:00:04 AM »
The side view doesn't offend quite as badly, but even the newest E-Type enthusiast can tell that something's not quite right. Still and all, you have to respect the effort and engineering that went into creating it. If this is what the builder wanted, he got it.
« Reply #34 on: June 03, 2013, 05:47:26 AM »
http://www.autopuzzles.com/forum/index.php?topic=8225.msg91040#msg91040
Thanks.
I've merged them.
The AP search for "Cheetah" didn't show that result at all!!
Re: Q506 - solved - 1989 Cheetah
« Reply #35 on: June 03, 2013, 05:49:12 AM »
I found it there...but I've noticed that now in the results you can't view the topic title and it's highly harder like that...but I have to check the settings and probably it can be fixed.
