Author Topic: Solved - NEH 2372: B&B Manufacturing HCS Racing Coupe  (Read 521 times)
« on: January 10, 2013, 05:30:33 AM »
What's this and who built it - for 1 point?:
Re: NEH 2372
« Reply #1 on: January 17, 2013, 05:13:29 AM »
Re: NEH 2372
« Reply #2 on: January 17, 2013, 02:42:02 PM »
Triumph bonnet catches, so based on a Triumph chassis?
Re: NEH 2372
« Reply #3 on: January 18, 2013, 04:51:03 AM »
No Triumph parts at all that I am aware of!
Offline geology
  • Puzzle Points 213
  • Look but don't touch.
Re: NEH 2372
« Reply #4 on: January 19, 2013, 08:35:22 AM »
I think it's an HCS Racing Coupe built by Steve Hendrickson and Shelby Bankston from Missouri,
looks like this one
Re: NEH 2372
« Reply #5 on: January 19, 2013, 09:54:55 AM »
looks like this one
Correct!
Who built it though (you've mentioned the names of the owners of the manufacturer)?
Locked for your reply.
« Last Edit: January 20, 2013, 03:01:56 PM by Carnut »
Offline geology
  • Puzzle Points 213
Re: NEH 2372
« Reply #6 on: January 20, 2013, 03:55:21 AM »
always had it listed as a HCS, but now looking again,  it would seem to be by a company called B&B Manufacturing, another change to my database! I think I'll start again
Re: NEH 2372
« Reply #7 on: January 20, 2013, 06:05:22 AM »
That's the name I'm looking for!
Another point takes you dangerously close to becoming a Pro...
Re: Solved - NEH 2372: B&B Manufacturing HCS Racing Coupe
« Reply #8 on: January 20, 2013, 02:06:15 PM »
Did the car use a proprietary chassis, engine, gearbox and running gear?
« Reply #9 on: January 20, 2013, 03:04:41 PM »
Not everything, no:
Quote from the B&B website:
HCS Racing Coupe - $25,900.00
HAND LAID FIBERGLASS BODY
CUSTOM TUBE FRAME
PREWELDED MOTOR AND TRANS. MOUNTS
NARROWED 9" FORD REAREND
NEW MOSER AXLES
11" DISC REAR BRAKES
ADJUSTABLE 4 BAR TRAILING ARMS
QA1 ADJUSTABLE REAR COIL OVER SHOCKS
ADJUSTABLE TUBULAR FRONT SUSPENSION
QA1 ADJUSTABLE FRONT COIL OVER SHOCKS
WILWOOD FRONT BRAKES WITH CALIPERS
CUSTOM PEDAL ASSEMBLY MOUNTED
18 GAL. POLY URETHANE GAS TANK
STEERING INSTALLED WITH REMOVABLE HUB
COMPLETE LIGHT KIT INSTALLED
HOOD, DOORS AND TRUNK HINGED & LATCHED
WINDOW FRAMES & PLEXI GLASS WINDOWS INSTALLED
PLEXI GLASS COVERS NOT INSTALLED
ALUMINUM RADIATOR INSTALLED
PAINTED HEADERS & SIDE EXHUST NOT INSTALLED
ADJUSTABLE SWAY BARS FRONT & REAR
ADJUSTABLE PAN HARD BAR
KIRKHAM GAUGES WITH REVERSE SPEEDOMETER WITH SENDING UNITS
Unquote
It doesn't say what the engine is, so maybe it's the builder's choice?
« Last Edit: January 20, 2013, 04:23:19 PM by Carnut »
