Author Topic: Puzzle #917 - Solved! Colani Miura  (Read 1664 times)
« on: July 05, 2008, 07:06:25 AM »
Colani Miura
« Last Edit: July 07, 2008, 03:24:06 AM by Otto Puzzell »
Offline alecwolf
  • Country: hu
  • Puzzle Points 53
  • Fan of autohistory and carmodels
    • Autohistory
Re: Puzzle #917
« Reply #1 on: July 06, 2008, 08:57:51 AM »
This is one of the strange cars, built by Luigi Colani. This one was built in 1970, based on the Lamborghini Miura.
Offline Iluvatar
  • Puzzle Points 245
    • www.automobileitaliana.it
MPC#042 - Colani Le Mans with Lamborghini Miura engine
« Reply #2 on: November 11, 2013, 12:57:25 PM »
Identify this car for one point
« Last Edit: November 22, 2013, 02:14:05 PM by Iluvatar »
Facebook automobileitaliana
Instagram @autoitaliana
Offline prototypefan
  • Puzzle Points 19
Re: MPC#042
« Reply #3 on: November 21, 2013, 09:16:10 PM »
luigi colani prototype....lemans??
was on ebay, totally thrashed missing motor.....I wanted the wheels!!
Offline Iluvatar
  • Puzzle Points 245
Re: MPC#042
« Reply #4 on: November 22, 2013, 04:23:02 AM »
Yes! Colani Le Mans is the correct name...
Locked for you to find the engine which move it... it's easy with the car name...
Offline exekiel
  • Country: ar
  • Puzzle Points 54
Re: MPC#042
« Reply #5 on: November 22, 2013, 06:39:59 AM »
its a luigi colani miura lemans. it has the lamborghini miura running gear mounted on a separeta pod
Offline Iluvatar
  • Puzzle Points 245
Re: MPC#042
« Reply #6 on: November 22, 2013, 02:09:36 PM »
Sorry exekiel, but the puzzle was locked for prototypefan... so the point goes to him...
Offline Ecnelis
  • Holometamorphosis
  • Puzzle Points 148
  • Zenstation
    • AutoGEN
Re: MPC#042 - Colani Le Mans with Miura engine
« Reply #7 on: November 22, 2013, 02:15:30 PM »
And it's an repost (Iluvatar - your PM box is full): http://www.autopuzzles.com/forum/index.php?topic=4499.0 ;)
Any reliable source for "Le Mans" name? I have never heard it in pair with this car, which is sometimes called "Colambo".
Re: Puzzle #917 - Solved! Colani Miura
« Reply #8 on: November 22, 2013, 02:36:11 PM »
Merged!
Offline Iluvatar
  • Puzzle Points 245
« Reply #9 on: November 22, 2013, 05:17:25 PM »
Why my PM box is always full?? How can I see when it's full??  ???
« Reply #10 on: November 22, 2013, 07:32:49 PM »
It has a limit..
You need to empty it from time to time then you can get new PM's
I was going to merge this one when it was solved, and note that it was only called the 'Miura' last time around.  Many Colani cars are named 'Something Le Mans' or 'Le Mans Something', or even just 'Le Mans', but I'm not sure Le Mans is correctly attached to this one?
« Reply #11 on: November 22, 2013, 07:36:33 PM »
Exekiel - you need to be careful to note 'locks' which means only the puzzler for whom the puzzle is locked may answer.  If you post a reply which solves the puzzle when it's locked for someone else you won't get the point and the puzzle will either be moved to Solved without any points being awarded or your post will be removed for the answer to be posted by the lockee.
You did the same thing on nicanary's NIC #50 so please be careful not to post a reply when it's locked for someone else!  Thanks.
