Author Topic: Solved: Wendax 810 - Auto Union 1000 S with 1000 Sp rear end (Erb 1000 K?)  (Read 753 times)
  • Puzzle Points 2352
You better take a close look...
Re: Wendax 810
« Reply #1 on: February 22, 2013, 02:40:24 AM »
Re: Wendax 810
« Reply #2 on: February 22, 2013, 04:57:09 AM »
Your question suggests there is something strange in this Auto Union 1000 sp coupe...but I cannot find it.
Re: Wendax 810
« Reply #3 on: February 22, 2013, 05:28:18 AM »
Yes, there is something special about it. I won't tell you where to look, because that would give it almost away, but I can supply a similar view at a regular 1000 Sp Coupé:
Re: Wendax 810
« Reply #4 on: February 22, 2013, 05:55:03 AM »
The only difference I found, apart from the logos missing, is the flat lights with orange indicators, but I suppose they are wrong spare parts. Or perhaps it is a model for Italian market?
Re: Wendax 810
« Reply #5 on: February 22, 2013, 06:25:50 AM »
No, I didn't mean the wrong rear lights. There is something else different which leads the way to the solution.
  • Puzzle Points 652
Re: Wendax 810
« Reply #6 on: February 22, 2013, 06:29:10 AM »
Is it RHD? I think all 1000SPs were imported as LHD. The sun visor is down on that side. (Grasping at straws).
Re: Wendax 810
« Reply #7 on: February 22, 2013, 06:45:07 AM »
It is LHD, but you are focussing on the correct area of the car.
  • Puzzle Points 652
Re: Wendax 810
« Reply #8 on: February 22, 2013, 06:47:20 AM »
It has front quarter-lights, unlike the standard car. Pre-production model or prototype?
Re: Wendax 810
« Reply #9 on: February 22, 2013, 06:58:38 AM »
Yes, that is the indication that this car is not a 1000 Sp. It is not a factory prototype, but a private one-off. Find out about the rest of the car and the point is yours.
Offline Hiawatha
  • Puzzle Points 530
Re: Wendax 810
« Reply #10 on: February 25, 2013, 02:41:19 PM »
It's difficult to put into decent english..Is it two different cars grafted together?
Re: Wendax 810
« Reply #11 on: February 25, 2013, 02:42:57 PM »
Yes! And I give you a hint: they are related.
Offline Hiawatha
  • Puzzle Points 530
Re: Wendax 810
« Reply #12 on: February 25, 2013, 03:01:34 PM »
DKW Junior?
Re: Wendax 810
« Reply #13 on: February 25, 2013, 03:07:16 PM »
You've understood the hint, but it is not a DKW Junior.
Offline Hiawatha
  • Puzzle Points 530
Re: Wendax 810
« Reply #14 on: February 25, 2013, 03:15:39 PM »
Sonderklasse?
Re: Wendax 810
« Reply #15 on: February 25, 2013, 04:06:34 PM »
Getting much closer
  • Puzzle Points 652
Re: Wendax 810
« Reply #16 on: February 25, 2013, 06:40:17 PM »
1000S front and 1000SP rear?
Re: Wendax 810
« Reply #17 on: February 26, 2013, 02:08:19 AM »
Yes, that's it. The online ad said that it was built in the 1960s. I'm not sure about the builder, it could be called Erb 1000 K.
One point for you.
  • Puzzle Points 652
Re: Solved: Wendax 810 - Auto Union 1000 S with 1000 Sp rear end (Erb 1000 K?)
« Reply #18 on: February 26, 2013, 05:29:58 AM »
That car is hideous!  Sorry, Hiawatha - I would have given you a point for Sonderklasse, if it had been my puzzle.
Offline Hiawatha
  • Puzzle Points 530
« Reply #19 on: February 26, 2013, 09:54:02 AM »
No problem, apparently the Sonderklasse is earlier, but that's exactly what I had in mind. It's really ugly aniway.
« Reply #20 on: February 26, 2013, 02:17:46 PM »
When I see something like this I have to ask "Why"
The only answer I can think of is that a competent panel beater, who had no aesthetic sense, had a rear-ended SonderKlasse and a front-ended 1000SP in his yard and a thin order book so he had to do something to fill his time
« Reply #21 on: February 26, 2013, 03:44:21 PM »
... and if you look at the front wings, you can see that he even must have lowered the sedan body to make it fit to the 1000 Sp rear end. Strange, but true!
