Author Topic: CG #45 - Phoenix Quadcar  (Read 386 times)
Offline Craig Gillingham
  • Country: au
  • Puzzle Points 236
« on: August 08, 2012, 06:14:52 AM »
For 1 point, just tell me the make of this car.
For another point, tell me what the make of the engine is.
« Last Edit: August 15, 2012, 08:20:26 AM by Craig Gillingham »
  • Country: au
  • Puzzle Points 236
Re: CG #45
« Reply #1 on: August 14, 2012, 09:50:41 PM »
Up to Professional level.
I've added another photo, it's a different car, but the same make.
  • Puzzle Points 1184
Re: CG #45
« Reply #2 on: August 15, 2012, 12:42:19 AM »
I found the original picture (wasn't too difficult :) ), but there's no identification of the make. How did you do it :)?
  • Country: au
  • Puzzle Points 236
Re: CG #45
« Reply #3 on: August 15, 2012, 12:57:15 AM »
After I found the photo, I asked an expert I know on early cars what it was, and he knew straight away. There are a few other cars similar to this one on the web, so it isn't completely obscure.
Re: CG #45
« Reply #4 on: August 15, 2012, 01:14:28 AM »
British?
  • Country: au
  • Puzzle Points 236
Re: CG #45
« Reply #5 on: August 15, 2012, 01:22:10 AM »
British?
Yep.
Re: CG #45
« Reply #6 on: August 15, 2012, 01:55:22 AM »
an early Thornycroft?
  • Country: au
  • Puzzle Points 236
Re: CG #45
« Reply #7 on: August 15, 2012, 02:11:07 AM »
No, sorry.
Re: CG #45
« Reply #8 on: August 15, 2012, 03:31:15 AM »
Steam powered?
  • Country: au
  • Puzzle Points 236
Re: CG #45
« Reply #9 on: August 15, 2012, 03:34:15 AM »
Steam powered?
No, just a normal petrol engine.
  • Puzzle Points 414
Re: CG #45
« Reply #10 on: August 15, 2012, 04:17:05 AM »
That seems to be an 8 h.p.  Phœnix of about 1907. Their slightly earlier version was called the "Quadcar" and I think this was as well.
I should know as in 1911 the Phœnix company moved to Letchworth, where I live, and I did once own a rather later 12 h.p. Phœnix
  • Country: au
  • Puzzle Points 236
Re: CG #45
« Reply #11 on: August 15, 2012, 04:31:41 AM »
Exactly correct. LOCKED for you to tell me what make of engine this has got, which I think you'll find easy.
  • Puzzle Points 414
Re: CG #45
« Reply #12 on: August 15, 2012, 08:01:06 AM »
Well as both Minerva and Fafnir engines were used, take your pick!
I think the Minerva engine they used was a single, so I'll say it's more likely a twin-cylinder Funfair Fafnir.
  • Country: au
  • Puzzle Points 236
Re: CG #45
« Reply #13 on: August 15, 2012, 08:12:24 AM »
I thought this model just had the traverse mounted twin cylinder Fafnir, the ones with the radiators mounted on either side. I didn't know they also had Minerva's. I know the smaller Trimo used a Minerva single. The attached photo shows the layout a bit better, and the fact that the bonnet on these puzzle cars was just cosmetic.
« Last Edit: August 15, 2012, 08:18:07 AM by Craig Gillingham »
