Author Topic: Solved: Wendax 436 - Volkswagen Express by Harmening  (Read 4257 times)
Re: Wendax 436
« Reply #25 on: February 10, 2012, 04:15:44 AM »
Yes, the puzzle train was used on Norderney. And it is called Bückeburger, because it was built in Bückeburg (that is the mentioned hint). There weren't too many coachbuilders in Bückeburg. Find out.
Re: Wendax 436
« Reply #26 on: February 10, 2012, 04:16:26 AM »
Is it locked for Oguerrerob ?
Re: Wendax 436
« Reply #27 on: February 10, 2012, 04:24:14 AM »
Re: Wendax 436
« Reply #28 on: February 10, 2012, 04:24:32 AM »
Should be Karosserie Hermann Harmening from Bückeburg. Inventor of the "Clubbus".
« Last Edit: February 10, 2012, 04:56:31 AM by Allemano »
Re: Wendax 436
« Reply #29 on: February 10, 2012, 04:28:56 AM »
Yes, it was built by Harmening. To complete this puzzle, give me the name this train was given (not Bückeburger), at least the one it had while used on Norderney.
Re: Wendax 436
« Reply #30 on: February 10, 2012, 04:33:03 AM »
I've found the name "Norderney Express Strandbahn".
(...) Die Karosserie dieser Bahn wurde ca. 1955 auf ein 1952er Käfer Chassis von der Firma Harmening / Bückeburg gesetzt. (...) die später auch als Norderney Express Strandbahn eingesetzt wurde
In 1955 the body of this train was built on a 1952 VW beetle chassis by Harmening of Bückeburg. Later it was used as the "Norderney Express Strandbahn" (beach-train)
« Last Edit: February 10, 2012, 04:38:05 AM by Allemano »
Re: Wendax 436
« Reply #31 on: February 10, 2012, 04:35:05 AM »
Yes, it was called Norderney Express, and later on when used in an animal park, it was called Metelen Express. Today it is the Prototyp Express.
One point for you, Allemano. Bad luck, Oguerrerob.
« Last Edit: February 10, 2012, 04:37:34 AM by Wendax »
Re: Solved: Wendax 436 - Volkswagen Express by Harmening
« Reply #32 on: February 10, 2012, 04:42:03 AM »
Seems sometime in its life it was named "Heide-Express", too.
(PDF attached)
« Reply #33 on: February 10, 2012, 04:52:14 AM »
Thanks, I haven't seen this article before.
« Reply #34 on: February 10, 2012, 12:30:01 PM »
Some more pics how it looks after restoration:
« Reply #35 on: February 14, 2012, 01:55:28 PM »
A picture from Norderney:
« Reply #36 on: March 27, 2012, 04:32:57 PM »
A later version (from 1960) with stock VW front:
« Reply #37 on: May 12, 2017, 01:51:17 PM »
Another one:
Online nicanary
  • Puzzle Points 632
« Reply #38 on: October 31, 2018, 02:37:57 PM »
Another period photo of the "train" at the Brussels Expo.
« Reply #39 on: December 09, 2020, 02:06:34 PM »
And the same as in reply #37 at the Interbau exposition in Berlin:
