Author Topic: Solved - NEH 2215: Skoda 720 AD-4 Combi Prototype by ItalDesign - 1971  (Read 792 times)
1 point for this car's correct ID and from when it dates:
« Last Edit: November 19, 2012, 10:06:06 AM by Carnut »
Re: NEH 2215
« Reply #1 on: November 16, 2012, 06:32:41 AM »
Offline Delorean
  • Puzzle Points 201
Re: NEH 2215
« Reply #2 on: November 16, 2012, 06:53:54 AM »
Looks like an Estate version of the Skoda 720 .... but I thought that one was a one-off?
Re: NEH 2215
« Reply #3 on: November 16, 2012, 08:48:47 AM »
That is what it is, yes.  They made various different proposals.
And just to answer all the questions for your point - when does it date from?
Locked for you!
Offline Delorean
  • Puzzle Points 201
Re: NEH 2215
« Reply #4 on: November 16, 2012, 11:14:38 AM »
Well, the Skoda 720 dates from 1971 and the Estate version - I had to look it up - from 1972 ...
Re: NEH 2215
« Reply #5 on: November 16, 2012, 12:10:00 PM »
It must be wrong there then because it's not 1972!
Offline Trommel
  • Puzzle Points 70
Re: NEH 2215
« Reply #6 on: November 16, 2012, 12:19:16 PM »
Still locked?
Re: NEH 2215
« Reply #7 on: November 16, 2012, 02:18:27 PM »
Still locked?
Yes - he's really got the puzzle and the date is only a minor details so it wouldn't be fair to open it up.
Offline milos62
  • Country: sk
  • Puzzle Points 60
Re: NEH 2215
« Reply #8 on: November 16, 2012, 03:31:59 PM »
 --- VI. 1971---
Re: NEH 2215
« Reply #9 on: November 16, 2012, 03:54:52 PM »
--- VI. 1971---
Er.. you do understand what a lock is?
In case you don't it means only delorean may answer..!
Offline Julien1A
  • Puzzle Points 74
Re: NEH 2215
« Reply #10 on: November 16, 2012, 07:31:47 PM »
What is the story behind the Skoda 720?... i seems that google only has Czech articles about it...
Offline Delorean
  • Puzzle Points 201
Re: NEH 2215
« Reply #11 on: November 17, 2012, 05:57:27 AM »
Same as the sedan then: 1971 ?
Re: NEH 2215
« Reply #12 on: November 19, 2012, 04:54:12 AM »
There seem to be various different dates on different websites for this car!
I had it as 1969, but I've seen it as both 1982 and 1971 too.
So we'll call this one solved and maybe a Skoda expert will tell us which date is right?!
I don't know much about it apart from what's on Czech/Polish websites.
Maybe a Skoda expert can help, but I will see what I can find on the sources I used.
« Last Edit: November 19, 2012, 05:04:14 AM by Carnut »
Offline Trommel
  • Puzzle Points 70
Re: Solved - NEH 2215: skoda 720 Combi Prototype - 1969/72?
« Reply #13 on: November 19, 2012, 07:13:34 AM »
I believe it's a Giugario/Italdesign study from 1969.
« Reply #14 on: November 19, 2012, 07:17:50 AM »
Interesting.  I got the 1969 date from a Polish website so seems it might be right after all..
EDIT:
I've looked a bit further into it and this is the (Google translated!) blurb about this car:
QUOTE
Skoda 720 ID Combi , Czechoslovakia 1969
five-door four to relocation car station wagon, engine front and rear wheel drive. In-line four-cylinder OHC, 1498 cm ł capacity, 80 mm bore and 74.5 mm stroke, 9.0 compression, Weber carburetor, power 63 kW (85 hp) at 5300 rev / min, torque 125 Nm at 4000 r / min . Four-speed transmission, wheelbase 2550 mm, weight 1150 kg, maximum speed 150 km / h and acceleration to a hundred for 17 s
prototype Series 720, designed by Giugiaro body station wagon (ItalDesign). None of the prototypes of type 720 with forthcoming series. Photographs is from the book "Too bad - let winged arrow".
UNQUOTE
« Last Edit: November 19, 2012, 07:58:55 AM by Carnut »
Offline milos62
  • Country: sk
  • Puzzle Points 60
Re: Solved - NEH 2215: Skoda 720 Combi Prototype by ItalDesign - 1969
« Reply #15 on: November 19, 2012, 08:21:58 AM »
The car is a prototype of the Škoda 720 AD-4 / Combi / introduced in June 1971st.
« Reply #16 on: November 19, 2012, 10:05:44 AM »
I'll change the heading.
