Author Topic: Solved - MJW #834 - Lancia Lambda Saloon converted by Woodall Nicholson  (Read 1011 times)
Make, model, and coachbuilder will earn you one point
Re: MJW #834
« Reply #1 on: January 22, 2012, 08:47:25 PM »
Offline bentleybob
  • Puzzle Points 201
Re: MJW #834
« Reply #2 on: January 23, 2012, 06:04:00 AM »
ca.1927 Lancia Lambda Saloon by Garavini?
Re: MJW #834
« Reply #3 on: January 23, 2012, 10:36:15 AM »
It is a Lancia Lambda that has been rebodied as a saloon. It was originally a tourer.
I don't have any dates and the coachbuilder isn't Garavini.
Re: MJW #834
« Reply #4 on: January 27, 2012, 08:47:11 PM »
Pro's?
Offline Joćo
  • Puzzle Points 881
Re: MJW #834
« Reply #5 on: January 27, 2012, 09:04:54 PM »
Lancia Lambda by Höhener?
Re: MJW #834
« Reply #6 on: January 28, 2012, 03:17:45 AM »
Not by them.
The coachbuilder is not Italian or Swiss.
Offline Joćo
  • Puzzle Points 881
Re: MJW #834
« Reply #7 on: January 28, 2012, 09:14:28 AM »
Belgian?
Re: MJW #834
« Reply #8 on: January 28, 2012, 09:57:51 AM »
Offline Joćo
  • Puzzle Points 881
Re: MJW #834
« Reply #9 on: January 29, 2012, 05:59:24 AM »
British?
Re: MJW #834
« Reply #10 on: January 29, 2012, 12:24:26 PM »
Yes it's British
Offline bentleybob
  • Puzzle Points 201
Re: MJW #834
« Reply #11 on: January 30, 2012, 05:33:45 AM »
I would not be surprised if this is so called portable hardtop saloon. The lower part is standard open Lancia tourer, the top is detachable and can be fitted for the cold season. It was quite a common practice on cars, the Lancia Lambda even more so, because there was a strong monocoque construction in the open tourer as it was. As for the top builder, Harrington?
Re: MJW #834
« Reply #12 on: January 30, 2012, 05:26:26 PM »
Yes, I believe you are correct in that the base was a standard Lancia Lambda tourer that was converted to a saloon by two names, the British coachbuilder.
Offline bentleybob
  • Puzzle Points 201
Re: MJW #834
« Reply #13 on: January 30, 2012, 06:36:04 PM »
Freestone & Webb?
Re: MJW #834
« Reply #14 on: January 31, 2012, 01:42:55 AM »
Freestone & Webb?
Not that, lesser known and the two names don't normally have an '&' between them.....
Re: MJW #834
« Reply #15 on: January 31, 2012, 02:20:48 AM »
Beddoes Moore?
  • Puzzle Points 413
Re: MJW #834
« Reply #16 on: January 31, 2012, 03:46:53 AM »
Well it looks a bit Weymann-like so perhaps it was J. Gurney Nutting (which is of course the man's name, so isn't two names whatever it looks like).
Offline bentleybob
  • Puzzle Points 201
Re: MJW #834
« Reply #17 on: January 31, 2012, 05:44:01 AM »
Martin Walter?
Re: MJW #834
« Reply #18 on: January 31, 2012, 12:59:11 PM »
Martin Walter?
Not by them - the names are a bit longer
Re: MJW #834
« Reply #19 on: January 31, 2012, 01:53:18 PM »
Although mainly known for their hearses, Woodall Nicholson would fit the requirements.
Re: MJW #834
« Reply #20 on: February 01, 2012, 01:02:41 AM »
Woodall Nicholson is correct.
See original photo below -
