Author Topic: AL76 - 1903 Lea-Francis designed by Alexander Craig  (Read 684 times)
  • Puzzle Points 413
« on: July 25, 2012, 05:40:31 AM »
Well it's about time we had something that wasn't made of pressed steel sheet so here's one for the early car fans.
One point for the maker and year and a second point for the engineer responsible for the design.
A further point if you can identify the relevance of another maker.
« Last Edit: August 19, 2014, 04:48:07 AM by Allan L »
Offline frederick59
  • Puzzle Points 171
Re: AL76 - another early one
« Reply #1 on: July 25, 2012, 07:09:48 PM »
Is it french?
  • Puzzle Points 413
« Reply #2 on: July 26, 2012, 03:32:41 AM »
Offline frederick59
  • Puzzle Points 171
« Reply #3 on: July 26, 2012, 05:47:06 AM »
from the houses behind it must come from the UK :)
  • Puzzle Points 413
« Reply #4 on: July 26, 2012, 07:34:41 AM »
Yes it does!
I'd offer another point for identifying the location, but this is Autopuzzles. isn't it?
Offline frederick59
  • Puzzle Points 171
« Reply #5 on: July 26, 2012, 08:49:28 AM »
could it be a Daimler?
  • Puzzle Points 413
« Reply #6 on: July 26, 2012, 08:57:12 AM »
No it couldn't.
Offline Trommel
  • Puzzle Points 70
« Reply #7 on: July 26, 2012, 11:01:11 AM »
Steamer?
  • Puzzle Points 413
« Reply #8 on: July 26, 2012, 01:55:20 PM »
  • Puzzle Points 413
« Reply #9 on: July 28, 2012, 06:27:54 PM »
81 viewings and we've only got this far?
Have we promoted all the old car enthusiasts to Expert and above already?!
  • Puzzle Points 413
« Reply #10 on: August 01, 2012, 04:33:50 AM »
OK it's been with the rookies for a fortnight and there are so many unsolved rookie puzzles that it was down to page three.
Let's see how long the experts take to solve this!
RayTheRat
« Reply #11 on: August 01, 2012, 10:24:40 AM »
Lanchester?
  • Puzzle Points 413
« Reply #12 on: August 01, 2012, 10:39:26 AM »
Not a Lanchester but just as eccentric in its own way!
  • Puzzle Points 413
« Reply #13 on: August 14, 2012, 03:59:18 AM »
OK it's been with the experts for a fortnight and there are so many unsolved expert puzzles that it was down to page three (just as it stuck in the rookies section).
Let's see how long the pros take to solve this!
« Reply #14 on: August 14, 2012, 05:12:30 AM »
Is it a Pilgrim, built by Pilgrim's Way Motor Works of Farnham? The engineer would be F. Leigh Matineau then.
  • Puzzle Points 413
« Reply #15 on: August 14, 2012, 05:32:40 AM »
No it is not, but I see that it does have at least one unusual feature in common.
« Reply #16 on: August 14, 2012, 05:37:28 AM »
Singer 8-10 hp resp. 12-14 hp with Lea-Francis engines, engineer Alexander Craig?
« Last Edit: August 14, 2012, 05:42:41 AM by Wendax »
  • Puzzle Points 413
« Reply #17 on: August 14, 2012, 08:29:09 AM »
Now you are on the right track - I'll just say that Alexander Craig is the right engineer.
« Reply #18 on: August 14, 2012, 08:32:31 AM »
Could it be the first Lea-Francis from 1903?
Is the connected marque Maudslay where Craig worked before?
« Last Edit: August 14, 2012, 08:35:21 AM by Wendax »
  • Puzzle Points 413
« Reply #19 on: August 14, 2012, 09:07:02 AM »
It could be just that car but, although Maudslay wasn't the connected marque I had in mind, you have really answered the puzzle if you put together elements of two of your three posts!
Locked for you to do that!
« Reply #20 on: August 14, 2012, 09:29:00 AM »
I'm not quite sure if I understood what's right and what's not. I'll have a try:
The puzzle car is one of three 1903 Lea-Francis built.
The responsible engineer was Alexander Craig.
The horizontal engine was used for the first four-wheel Singer cars which would be the connected marque.
  • Puzzle Points 413
« Reply #21 on: August 14, 2012, 09:48:01 AM »
That's right!
Two points of anyone's money!
I understand that the Singer was not much different from the Lea-Francis as a car, but we have not found detailed pictures yet.
My comment about the Pilgrim was because it too had a horizontal engine with the crankshaft across the car.
« Reply #22 on: August 14, 2012, 09:54:50 AM »
That's where my detective work started: the car looked like it had a flat (horizontal) engine underneath the seats, so I tried to find a suitable car...
Perhaps I should have have looked at the puzzle poster's personal favorite marque first.  ;)
  • Puzzle Points 413
« Reply #23 on: August 14, 2012, 09:56:45 AM »
Yes and if you look on the website where you found that photo you will find photos of puzzler and his car (as seen rather smaller to the left of this!).
