Author Topic: 1950 Lancia Aurelia/1950 FIAT 1400/1949 FIAT 1500 by Castagna  (Read 904 times)
Offline Tackitt
  • Puzzle Points 91
  • Thumb
Terribly disappointed in our rookies. But this has been languishing long enough.
Experts, knock this one out.
For a point: Make, model and coachbuilder please.
« Last Edit: July 23, 2012, 03:16:45 PM by Tackitt »
Offline fgsavoia
  • Puzzle Points 23
Re: Tackitt #9
« Reply #1 on: July 16, 2012, 03:58:59 PM »
This horrible line could be a late '40 early  - '50 Castagna's work
Re: Tackitt #9
« Reply #2 on: July 16, 2012, 05:22:21 PM »
I have it as a 1950 Lancia Aurelia by Castagna.  Is there another photo of it out there?
Offline als15
  • Puzzle Points 196
  • Fiat Author
Re: Tackitt #9
« Reply #3 on: July 16, 2012, 05:47:23 PM »
It was built in 1949 on a Fiat 1500 E chassis. Definitely, not a great design.  :yuck:
Offline Tackitt
  • Puzzle Points 91
  • Thumb
Re: Tackitt #9
« Reply #4 on: July 16, 2012, 10:24:26 PM »
A 1950 Lancia Aurelia by Castagna it is. You have your point.
Offline als15
  • Puzzle Points 196
  • Fiat Author
Re: 1950 Lancia Aurelia by Castagna
« Reply #5 on: July 17, 2012, 02:34:21 AM »
Where have you got the info that it's an Aurelia?
I have seen original Castagna press-pictures with "Fiat 1500" as a caption on the back (and unfortunately only scanned the front  >:().
« Reply #6 on: July 17, 2012, 07:10:56 AM »
I found two copies of the same picture online.  One indicates it is a 1950 Lancia, the other indicates it is a 1949 Fiat.
Unless another online source is verified, I would look upon als15 as being a new source that verifies this as being a Fiat.
« Reply #7 on: July 17, 2012, 07:22:42 AM »
I have this car as a 1949 Fiat 1400 Berlina by Castagna and would tend to agree with Alessandro
Offline als15
  • Puzzle Points 196
  • Fiat Author
« Reply #8 on: July 17, 2012, 12:34:05 PM »
Front view and close-up of the emblem. It's not very readable, but it looks much more Fiat than Lancia.
Offline Tackitt
  • Puzzle Points 91
  • Thumb
« Reply #9 on: July 17, 2012, 08:13:00 PM »
After reviewing and combing through the net, I believe now that this is a 1949 Fiat 1400 Berlina by Castagna.  Woodinsight gets a point though I will not take SixteeScuda's point away as he found the same mistaken website I did.
Re: 1950 Lancia Aurelia/1949 FIAT 1400 by Castagna
« Reply #10 on: July 17, 2012, 10:05:58 PM »
As there are only 3 pictures, I suspect this monster was destroyed before too much time had passed.
Online Carnut
« Reply #11 on: July 18, 2012, 05:04:25 AM »
I've moved this one to 'Solved' rather than 'Solved - 2012' so that is doesn't get lost and gets more viewings.
Hope you don't mind.
« Reply #12 on: July 18, 2012, 05:10:28 AM »
Thank you for the point
« Reply #13 on: July 18, 2012, 05:15:24 AM »
I think it became this car:
http://www.autopuzzles.com/forum/index.php?topic=19310.0
Offline als15
  • Puzzle Points 196
  • Fiat Author
« Reply #14 on: July 18, 2012, 08:33:25 AM »
If I'm not wrong... I said it's a Fiat, not our friend Woodinsight... Sorry to say that, but the point should be mine...
« Reply #15 on: July 18, 2012, 11:07:20 AM »
I agree - I didn't really think I deserved the point as als15 had guessed the correct marque before I did.
Offline Tackitt
  • Puzzle Points 91
  • Thumb
« Reply #16 on: July 20, 2012, 08:28:44 PM »
It is done. Als, you have your point.
I originally based it on the fact that Woodinsight was the first to give the model as well as make as Als called it a 1500. But, since you were both in agreement...
Offline als15
  • Puzzle Points 196
  • Fiat Author
« Reply #17 on: July 21, 2012, 04:33:41 AM »
Thanks for the point.  :)
By the way, this cannot be a 1949 Fiat 1400 just because the 1400 was introduced in 1950.
Because the last photo is taken from a book written by me... I explain the background.
I found those three pictures in a private archive and the caption on the back says: "Berlina a quattro porte su Fiat 1500 o Fiat 1400". It was common to present a model offering it on different bases.
However, I think it has been a one-off an most likely on the 1500 E, because it doesn't make any sense to build a saloon like that on a much more modern base as the 1400, unless a customers asks and pays  ;).
Probably I've been misleading putting all the 3 pictures in the book about the Fiat 1400, but the aim was to show them because I found them only after having published the book about the 1500, where I was only able to put a poor quality copy of the side view. It would have been better to underline that probably the 1400 version was only an idea... But I was young when I wrote that book and not as rigorous as a good historian should have been.
At the end of the day, I think that the correct title for the topic should be 1949 Fiat 1500 by Castagna.
« Reply #18 on: July 21, 2012, 05:38:20 AM »
Great to see the true facts emerging on this unusual car.
