Author Topic: Solved: Allemano's № 627 - Moskvich-415 Pilot / AZKL 4x4  (Read 1240 times)
Please respond below if you know the make and model designation of this car.
One point for the right and complete answer!
If you haven't registered yet, you'll need to do so in order to reply and to post your own puzzles
Re: Allemano's № 627
« Reply #1 on: May 25, 2011, 07:18:06 AM »
Experts!
Offline DeAutogids
  • Puzzle Points 204
  • This text is just for you!
    • dAuto.nl
« Reply #2 on: May 25, 2011, 12:27:50 PM »
From an Asian country?
« Reply #3 on: May 25, 2011, 12:33:48 PM »
Yes/No
Offline Tackitt
  • Puzzle Points 91
  • Thumb
« Reply #4 on: May 25, 2011, 02:36:39 PM »
Mahindra?
« Reply #5 on: May 25, 2011, 02:55:41 PM »
From Turkey?
Offline Aaron65
  • Puzzle Points 209
  • Midland St.
« Reply #7 on: May 25, 2011, 05:04:43 PM »
Russian?
« Reply #8 on: May 25, 2011, 05:06:58 PM »
Offline Aaron65
  • Puzzle Points 209
  • Midland St.
« Reply #9 on: May 25, 2011, 05:16:07 PM »
Is it a UAZ?
« Reply #10 on: May 26, 2011, 01:07:57 AM »
Offline Aaron65
  • Puzzle Points 209
  • Midland St.
« Reply #11 on: May 26, 2011, 07:45:22 AM »
Is it from a "well-known" automaker or is it a homebuilt?
« Reply #12 on: May 26, 2011, 07:47:02 AM »
Well known.
Offline Aaron65
  • Puzzle Points 209
  • Midland St.
« Reply #13 on: May 26, 2011, 08:02:43 AM »
GAZ?
Offline thorax
  • Puzzle Points 394
« Reply #14 on: May 26, 2011, 08:03:03 AM »
Lada?
FRIUL LIBAR
« Reply #15 on: May 26, 2011, 08:21:37 AM »
No to both
Offline thorax
  • Puzzle Points 394
« Reply #16 on: May 26, 2011, 08:27:04 AM »
Moskvich?
FRIUL LIBAR
« Reply #17 on: May 26, 2011, 08:28:47 AM »
Moskvich?
Getting close, though this car was apparently never called Moskvich.
Offline thorax
  • Puzzle Points 394
« Reply #18 on: May 26, 2011, 08:35:06 AM »
it was the first prototype of civilian jeep in Russia studied by MZMA: the 415 with canopy anda the 416 all closed metal body (the first SUV!).
I've two sources that calls it Moskvich-415 Pilot (1959)
FRIUL LIBAR
« Reply #19 on: May 26, 2011, 08:50:54 AM »
Um... problem with those Russian sources is I can't confirm if you are right or wrong. You clearly identified the right car as far as I can tell, but I have it simply as AZKL 4x4. Any Russian speakers out there?
Any way I give you one point.
Offline thorax
  • Puzzle Points 394
« Reply #20 on: May 26, 2011, 09:06:03 AM »
thanks! there is another French source
FRIUL LIBAR
« Reply #21 on: May 30, 2011, 01:37:09 AM »
Offline Siata1
  • Puzzle Points 104
« Reply #22 on: June 23, 2011, 05:34:51 PM »
I don't speak russian - but my source says:
AZLK (АЗЛК - Автомобильный завод имени Ленинского Комсомола in Russian) was a Russian automobile factory (Moscow), the maker of the Moskvitch brand.
Re: Solved: Allemano's № 627 - Moskvich-415 Pilot / AZKL 4x4
« Reply #23 on: June 25, 2011, 03:56:54 AM »
Declared as solved.
« Last Edit: June 25, 2011, 04:06:14 AM by Allemano »
  • Puzzle Points 1179
« Reply #24 on: June 25, 2011, 06:28:26 AM »
One of the best sites on Russian automotive history says this was first called Moskvitch 4x4. It was a prototype, built in 1958, reminiscent of Willys Jeep. Then the military tested it and with their recommendations updated prototypes were built, callede Moskvitch 415.
