Author Topic: Solved - NEH 1075: 1948 Lippincott proposal for Tucker Talisman by Phillip Egan  (Read 686 times)
What's this, by whom and from when?
1 point if you can get all three right!
« Last Edit: May 06, 2011, 06:50:35 PM by Carnut »
Offline bleyland
  • Puzzle Points 11
Re: NEH 1075
« Reply #1 on: May 05, 2011, 12:42:41 AM »
One of the early sketches for the Tucker '48 Talisman?
Re: NEH 1075
« Reply #2 on: May 05, 2011, 05:28:06 AM »
Yes!  By?
(Locked for bleyland's reply.)
« Last Edit: May 05, 2011, 05:33:58 AM by Carnut »
Offline bleyland
  • Puzzle Points 11
Re: NEH 1075
« Reply #3 on: May 05, 2011, 11:08:28 AM »
Philip Egan is usually credited for this one because he's the only one seen working on it.
Re: NEH 1075
« Reply #4 on: May 05, 2011, 11:49:34 AM »
Oh.. It's not the name I have!
If you can PM me some proof I can be persuaded but otherwise I'll have to stick out for the name I have.
I'll keep it locked for you for another try..
Offline bleyland
  • Puzzle Points 11
Re: NEH 1075
« Reply #5 on: May 05, 2011, 12:41:03 PM »
I think the name you have is Alex Tremulis, but I've PM you some info on Egan
Re: NEH 1075
« Reply #6 on: May 06, 2011, 10:53:38 AM »
Actually Tremulis did do a proposal entitled Tucker Talisman but it wasn't this car.
Although Egan did work on the puzzle car he used as a basis someone else's work, and although you are correct in naming Philip Egan I really need the name of the guy who originated the design.
Locked for you to see what you can find!
Offline bleyland
  • Puzzle Points 11
Re: NEH 1075
« Reply #7 on: May 06, 2011, 12:15:57 PM »
Eagan worked for Lippincott, which was the design firm that did that drawing:
>>> link removed <<<
« Last Edit: May 06, 2011, 12:46:38 PM by Allemano »
Re: NEH 1075
« Reply #8 on: May 06, 2011, 12:45:58 PM »
bleyland, please do not link. It's verboten in the puzzle areas of this forum. Take a look here!
This is your first warning!
« Last Edit: May 06, 2011, 03:41:30 PM by Allemano »
Re: NEH 1075
« Reply #9 on: May 06, 2011, 03:12:51 PM »
Yes, you've got all there is now I think!
Well done.
Unmodified picture:
« Last Edit: May 06, 2011, 03:34:06 PM by Carnut »
Now in clay.
