Author Topic: Solved - MJW #536 - Opel 2 litre Saloon by Vetter 1936 (designer Paul Jaray)  (Read 474 times)
Make, coachbuilder and year please
« Last Edit: August 01, 2011, 10:32:37 AM by woodinsight »
Offline serra
  • Puzzle Points 265
Re: MJW #536
« Reply #1 on: July 31, 2011, 04:13:30 AM »
I think it is an Opel with body designed by Paul Jaray in early 30s.
Re: MJW #536
« Reply #2 on: July 31, 2011, 04:57:55 AM »
Opel designed on the principles of Paul Jaray is correct but it is not early 1930s but mid 1930s.
However for the point I need the coachbuilder.
Locked for you.
Offline serra
  • Puzzle Points 265
Re: MJW #536
« Reply #3 on: August 01, 2011, 03:45:21 AM »
Sorry I dont know the coachbuilder I will try to guess it so you can unlock it. I supose that It will be a German coachbuilder so, could be Sophn?
Re: MJW #536
« Reply #4 on: August 01, 2011, 04:35:29 AM »
German coachbuilder is correct. Not Spohn.
One more guess for you before I open it up again.
Coachbuilder begins with V.....
Offline serra
  • Puzzle Points 265
Re: MJW #536
« Reply #5 on: August 01, 2011, 09:44:31 AM »
Thanks for the opportynity and the clue, I have found a conection between Paul Jaray and a German coachbuilder named Vetter (Walter Vetter Karosserie). I cant understand German so I could be wrong with google traduction but it seems that Vetter comes to terms with Jaray to use its principles in the bodies of his buses. so could be Vetter . ;)
Re: MJW #536
« Reply #6 on: August 01, 2011, 09:51:56 AM »
Vetter it is.
Another point for you.
  • Puzzle Points 2353
It was based on an Opel 2 Liter.
Okay, thanks
