Author Topic: #DM8 Goggomobil Carry All  (Read 906 times)
Offline DynaMike
  • Puzzle Points 230
  • Amsterdam, cool.
« on: August 09, 2009, 01:20:16 PM »
Please tell me name and origin of this fridge-like little van, and yoou'll get a point:
« Last Edit: September 02, 2018, 02:47:10 AM by Wendax »
  • Puzzle Points 1174
Re: #DM8 What is this?
« Reply #1 on: August 19, 2009, 01:47:07 PM »
Goggo "Carry-all", produced by Buckle Motors in Australia of which only a couple, maybe 20 were made in the late 1950s, early 1960s.
Offline DynaMike
  • Puzzle Points 230
  • Amsterdam, cool.
« Reply #2 on: August 19, 2009, 06:48:45 PM »
Very good!
I only have the make of this little van but can you also tell me which country it's in?
« Last Edit: May 25, 2011, 10:15:04 AM by woodinsight »
Re: MJW #438
« Reply #4 on: May 25, 2011, 12:36:11 AM »
Expert help needed
Offline barrett
  • Puzzle Points 374
  • Don't delete me
Re: MJW #438
« Reply #5 on: May 25, 2011, 12:55:47 AM »
This is the Australian version of the Goggomobile van, with a GRP body and built by Bill Buckle
Re: MJW #438
« Reply #6 on: May 25, 2011, 02:02:52 AM »
Correct!
Re: Solved - MJW #438 - Goggomobil Van by Bill Buckle, Australia
« Reply #7 on: May 25, 2011, 03:53:16 AM »
Actually it was called a Carryall wasn't it, dating from 1960?
That should be included in the title?
« Last Edit: May 25, 2011, 04:02:50 AM by Carnut »
  • Puzzle Points 2341
« Reply #8 on: May 25, 2011, 04:02:22 AM »
A period brochure:
« Reply #9 on: May 25, 2011, 05:41:33 AM »
Just a little bit more about this van.  Sorry about the less than perfect translation but this is straight from a German website and is not translated by me!
QUOTE
The next model was the Carry All van, were not of much construction. It's really a shame because the car was wide with his big load floor and the side cargo door of his time. This enabled him to walk from the loaded and unloaded. To save space, there was a sliding door that open when slipped into the roof area. The lower part of the body, was below the rubber strip from the Dart. The roof was molded from a FC Station Wagon. The windshield also came from the FC. There were no persons door. The passenger seat could be folded and so they came into the hold. A wooden floor has been assembled from plywood. The higher the floor to the height of the center tunnel so that a continuous loading surface was formed. The very front mounted driving position required that all cable and the gear were extended in the center tunnel. Since the steering wheel sat as far forward combined a sprocket with chain steering column and steering.
The rear lights were mounted horizontally on a sedan. An innovative feature are the vents, which brought on the side of air for cooling the engine. The ventilation slots are still available today at hardware stores.
UNQUOTE
« Reply #10 on: May 25, 2011, 10:10:00 AM »
I didn't have any more information on this one myself so thanks for the additional material.
Title altered now
The original unaltered photo
