Author Topic: Puzzle #1887 - Minning DSR  (Read 640 times)
« on: February 01, 2011, 03:09:55 AM »
Know the story? For 1 point, please respond below and identify the vehicle pictured.
If you haven't registered yet, you need to do so in order to reply.  You can do so by clicking here.
Also, please be sure to check out our other puzzles, and, please post a puzzle of your own
« Last Edit: February 25, 2011, 04:10:32 AM by Otto Puzzell »
Re: Puzzle #1887
« Reply #1 on: February 09, 2011, 03:45:53 AM »
Up
Re: Puzzle #1887
« Reply #2 on: February 09, 2011, 04:36:47 AM »
Those wheels look familiar..
Osca?
Re: Puzzle #1887
« Reply #3 on: February 13, 2011, 04:27:04 AM »
Not sure about the wheels; this car uses mechanicals from another make.
Re: Puzzle #1887
« Reply #4 on: February 24, 2011, 04:06:06 AM »
Up
Re: Puzzle #1887
« Reply #5 on: February 24, 2011, 05:20:58 AM »
From US of A?
Re: Puzzle #1887
« Reply #6 on: February 24, 2011, 06:32:08 AM »
Yes
Re: Puzzle #1887
« Reply #7 on: February 24, 2011, 07:14:43 AM »
The car looks pretty small - is it powered by a Mercury outboard engine?
Offline white12
  • Puzzle Points 228
Re: Puzzle #1887
« Reply #8 on: February 24, 2011, 08:06:39 AM »
My source says It is a special named  Minning built by Fred Minning around 1963-64. This source says it was originally Imp-powered. The car has an aluminum and fiberglass body on a square tube frame. It uses a mix of 600D, Abarth, and Fiat 850 running gear and now has Fiat 600D power.
Pro since 25-5-2010
Re: Puzzle #1887
« Reply #9 on: February 25, 2011, 04:09:01 AM »
Well done! This is the Minning DSR prototype, No. 00001. The car is an aluminum and fiberglass body on a square tube frame. It uses Fiat 600D power and a mix of 600D, Abarth, and Fiat 850 running gear.
The puzzle photo is the car as it first appeared. Over the years, it was modified and the color changed to white over blue.
