Author Topic: Solved: Wendax 203 - Morris Oxford Spider by Fiol  (Read 668 times)
  • Puzzle Points 2357
« on: May 28, 2011, 03:17:12 AM »
My source did irritate me about the name of this car, because it doesn't fit to the quite obvious base car.
For one point, please respond and identify the base car, the coachbuilder and the year it was built.
« Last Edit: July 10, 2020, 05:43:26 PM by Djetset »
Re: Wendax 203
« Reply #1 on: June 04, 2011, 02:58:07 AM »
Re: Wendax 203
« Reply #2 on: June 04, 2011, 03:19:54 PM »
Is the base car a Morris Oxford?
The coach builder: Micholetti?
The year:  1952?
Re: Wendax 203
« Reply #3 on: June 04, 2011, 03:24:01 PM »
I think so, although my source says something different, but it apparently is a Morris Oxford.
No (not even Michelotti  ;) )
The year:  1952?
Close
Re: Wendax 203
« Reply #4 on: June 04, 2011, 05:01:21 PM »
It is certainly a Morris Oxford MO grill, but I'm not sure about the rest.  :scratch:
The MO Oxford was always a 4-door and this is 2-door.  The contemporary Minor came in 2-door and 4-door versions so it might be a Minor with an Oxford grill.  But the wheelbase is too long for a Minor.  It also looks a lot lower than a Minor/ Oxford.  From the scuttle back it is not standard Morris at all as the front wingline does not go back that far - in fact it looks rather like a contemporary Opel Olympia.
In short, I'm totally flummoxed and simply putting my thoughts into words.   ???
And my apologies to Signor Michelotti for spelling his name wrong.   :-[
« Last Edit: June 04, 2011, 05:29:31 PM by D-type »
Offline Captain Slow
  • Puzzle Points 21
Re: Wendax 203
« Reply #5 on: June 07, 2011, 11:27:46 AM »
Wendax, does your source say Hindustan Fourteen? If so, it is an Oxford in all but name.
Re: Wendax 203
« Reply #6 on: June 08, 2011, 02:55:21 PM »
Which has to invite the question: Indian?
Re: Wendax 203
« Reply #7 on: June 08, 2011, 04:49:12 PM »
It is not Indian and it is not said to be a Hindustan.
Offline SACO
Re: Wendax 203
« Reply #8 on: June 13, 2011, 04:18:13 AM »
Wolseley by Fiol ,Spain 1955 ?
« Last Edit: June 13, 2011, 04:29:06 AM by SACO »
Re: Wendax 203
« Reply #9 on: June 13, 2011, 05:38:49 AM »
Yes, it is by Fiol and supposed to be a Wolseley. I have a different year though. Locked for you to supply the correct year.
Offline SACO
Re: Wendax 203
« Reply #10 on: June 13, 2011, 06:37:18 AM »
1951 ,sorry  :)
Re: Wendax 203
« Reply #11 on: June 13, 2011, 06:39:55 AM »
Another point for you.
Perhaps one of our Spanish members can shed some light on the "Wolseley mystery"?
Offline Tom_I
  • Puzzle Points 475
  • Toying around
Re: Solved: Wendax 203 - Wolseley (Morris Oxford?) Spider by Fiol
« Reply #12 on: June 13, 2011, 08:25:03 AM »
It's certainly a mystery.
The car clearly has the grille from a Morris Oxford MO, with a Morris badge above it. The nearest equivalent Wolseley was the 4/50, which had similar, but not identical, bodywork (the sculpting of the front doors is different). However, it had the traditional Wolseley radiator with the equally traditional illuminated badge set in it. Examples of both standard saloons attached, Morris above, Wolseley below.
