Author Topic: Solved - MJW #257 - Mille-Cent Ford Special  (Read 890 times)
« on: January 29, 2011, 01:33:35 PM »
What's the name of this racing special?
What engine did it use?
A point awaits....
Re: MJW #257
« Reply #1 on: February 02, 2011, 01:33:13 PM »
Expertise sought
Re: MJW #257
« Reply #2 on: February 02, 2011, 05:08:51 PM »
It looks as if it has Cooper ancestry - but it's not in The book  :(
So, is it Norton engined?
Re: MJW #257
« Reply #3 on: February 02, 2011, 11:43:34 PM »
The engine is not a Norton - rather more common than that
Re: MJW #257
« Reply #4 on: February 03, 2011, 12:01:14 AM »
On second thoughts I'm going to lock this one for you (until your next reply) as you are pretty close to a solution with your reply.
As I said above, the engine is not a Norton.
Despite not being in The Book it is Cooper based.
I would describe the car as being the first xxx xxx car designed for the xxx formula
Re: MJW #257
« Reply #5 on: February 03, 2011, 03:05:39 PM »
Blind guess
First rear engined car for the 1172 Formula.  And if that's right then the engine is a Ford 10
Please don't lock it again as I honestly haven't a clue.
Re: MJW #257
« Reply #6 on: February 03, 2011, 03:14:11 PM »
Yes - that's correct!
All I need is the name of the car.
I'll keep it locked for you in the meantime.
ps - the initials of the man behind the car is F.T. - well known in 1172cc circles.
Re: MJW #257
« Reply #7 on: February 03, 2011, 04:01:05 PM »
Still blundering around in the dark.
Could the  "T" be Turner?
Re: MJW #257
« Reply #8 on: February 04, 2011, 12:34:41 AM »
Sorry D-Type but I'll have to unlock it for others to have a guess.
Thanks for your replies - you were pretty close to solving it.
To sum up - this sports racer is fitted with a Ford 1172cc engine and was the first rear-engined car constructed for this formula.
Its name is ?
Online Wendax
  • Puzzle Points 2349
Re: MJW #257
« Reply #9 on: February 04, 2011, 06:46:06 AM »
Wavendon Wombat?
Re: MJW #257
« Reply #10 on: February 04, 2011, 07:49:40 AM »
Online Wendax
Re: MJW #257
« Reply #11 on: February 04, 2011, 08:02:29 AM »
F.T. being Frank Tiedeman?
Re: MJW #257
« Reply #12 on: February 04, 2011, 08:32:03 AM »
That's the man!
Online Wendax
Re: MJW #257
« Reply #13 on: February 04, 2011, 08:44:14 AM »
Is the car called Mille-Cent?
Re: MJW #257
« Reply #14 on: February 04, 2011, 09:38:17 AM »
That's correct and another point for you
