Author Topic: JC - WhatIsIt? - Solved by Amsterdam - Hanomag-Henschel with a Orion camper body  (Read 924 times)
Offline DeAutogids
  • Puzzle Points 204
  • This text is just for you!
    • dAuto.nl
What is this? Should be easy enough
« Last Edit: May 20, 2011, 09:42:54 AM by DeAutogids »
Offline DeAutogids
  • Puzzle Points 204
    • dAuto.nl
Re: JC - WhatIsIt?
« Reply #1 on: March 30, 2011, 05:47:35 AM »
I expected this one to be a lot easier.
Offline Amsterdam
  • Puzzle Points 179
  • xxxAMSTERDAMxxx
    • www.xanaduambulldogs.nl
Re: JC - WhatIsIt?
« Reply #2 on: March 30, 2011, 07:28:43 AM »
Orion by Ferdinant Schäfer ?
Offline DeAutogids
  • Puzzle Points 204
    • dAuto.nl
Re: JC - WhatIsIt?
« Reply #3 on: March 30, 2011, 07:51:06 AM »
That's one half.
Offline Amsterdam
  • Puzzle Points 179
  • xxxAMSTERDAMxxx
Re: JC - WhatIsIt?
« Reply #4 on: March 30, 2011, 07:55:31 AM »
Hanomag Henschel
Orion type 1 Ferdinant Schäfer Kunststoff Detmold 1969 Daimler Benz engine
« Last Edit: March 30, 2011, 08:11:03 AM by Amsterdam »
Offline Amsterdam
  • Puzzle Points 179
  • xxxAMSTERDAMxxx
Re: JC - WhatIsIt?
« Reply #5 on: March 31, 2011, 07:03:54 AM »
Hanomag Henschel
:bump:
Offline DeAutogids
  • Puzzle Points 204
    • dAuto.nl
Re: JC - WhatIsIt?
« Reply #6 on: March 31, 2011, 07:20:20 AM »
Let's just say it is a Hanomag-Henschel with a Orion camper body.
It is a Schäfer Orion I based on a chassis that was built by Hanomag (F 20 or F 25) at the time the Orion I appeared in 1968. So it could have either an Austin A60 gasoline engine or a Hanomag D301E2 diesel engine. In 1969 Hanomag merged with Henschel to the new make Hanomag-Henschel whose majority belonged to Mercedes-Benz. Soon the Hanomag Diesel engine was replaced by the Mercedes-Benz OM615. By the time the Hanomag-Henschel changed their name again, this time to become Mercedes-Benz, Ferdinand Schäfer had already introduced the Orion II with a front like the Hanomag-Henschel. The Orion I started with rounded headlamps as in the above picture. Later on, it was available with rectangular headlights as can be seen below.
Offline DeAutogids
  • Puzzle Points 204
    • dAuto.nl
Well, the chassis has been identified as Hanomag-Henschel - I am pretty sure that is correct. As for the engine: Anything goes ;)
I didn't doubt it, just wanted to add some information.  ;)
The Schäfer Orion I from behind, an Orion II and an Orion III:
Offline barrett
  • Puzzle Points 378
  • Don't delete me
...an Austin A60 gasoline engine...
 :o Wow. That must be deeply, deeply unpleasant to drive!
  • Puzzle Points 1177
And let's just mention here that Orion campers were produced in Hungary between cca 1972-1974 at the Balatonfüred Ship Factory. Two shells are known to survive.
If someone got time, I'd like to ask assistance on researching this in Germany.
