Author Topic: Solved - NEH 955: Jensen F-type "Esporanda" 1973  (Read 701 times)
« on: February 17, 2011, 10:09:39 AM »
1 point on offer for the Puzzler who knows what this is:
« Last Edit: March 11, 2011, 08:00:26 AM by Carnut »
Re: NEH 955
« Reply #1 on: March 10, 2011, 05:12:56 AM »
Offline navara
  • Puzzle Points 41
Re: NEH 955
« Reply #2 on: March 10, 2011, 05:14:20 PM »
This is the Jensen Esporanda, designed by William Towns. Intended as a replacement to the Interceptor. It was an official Jensen project.
But the oil crisis put an end the dream of this getting to production.
Autopuzzles has a link to the Jensen Esporando, not the same car, the esporando, was a privately converted C-V8 designed by Bob Curl, inspired by the Espada.
Offline del78
  • Puzzle Points 269
  • SiD
Re: NEH 955
« Reply #3 on: March 11, 2011, 03:01:33 AM »
i found it under the name Jensen F-Type Prototype
"The car which was to take over for Jensen FF,
never was to be more than a prototype."
Re: NEH 955
« Reply #4 on: March 11, 2011, 04:16:20 AM »
This is what I have it as too so 1 point to you!
I haven't seen the puzzle car referred to as an Esporanda, only as an F-type as del78 correctly said.  I would have locked it for you if yours had been the only reply, but obviously I can't do that!  However, since you clearly knew it was a Jensen, and it does look like a Bill Towns design (one of his most successful ones if indeed it was his), I'll give you a point IF you can show me some proof (by PM perhaps) that it was also called Esporando?
The other Esporando you refer to (which has featured on AP before) is pictured below, and is obviously no relation at all:
« Last Edit: March 11, 2011, 04:44:38 AM by Carnut »
Offline navara
  • Puzzle Points 41
Re: NEH 955
« Reply #5 on: March 11, 2011, 06:36:54 AM »
F type was the prototype code for the car. Esporanda was its registered model name.
to quote from Autocar 5th April 1980 ''Jensen Motors were anxious that a replacement, to be code named the F-type, soon be put in hand. After completion of a prototype program, production was approved, the Esporanda was registered with the SMMT ( society of motor manufacturers and traders) and a launch date was fixed for the 1973 Earls court show.
To quote page 177 of the book 'Jensen' talking about the F type '
Jensen had tentatively registered the name Esporanda for the new model.... '
 the author - a well known Jensen expert Keith Anderson!
The other car is Esporando, note the 'o' at the end, replacing the 'a' of the official car.
The Esporando was named as a kind of tribute to the F type Esporanda.
Re: NEH 955
« Reply #6 on: March 11, 2011, 07:24:12 AM »
Fascinating stuff!
Well worth a point..
