Author Topic: Solved: PN #127 -- Greenwheel AG-1 (HCEV-AC60-V2ND)  (Read 968 times)
  • Puzzle Points 1179
« on: November 22, 2010, 11:56:39 PM »
Can you recognise this one? Identify it correctly and a point will be yours!
Offline navara
  • Puzzle Points 41
Re: PN #127
« Reply #1 on: November 24, 2010, 03:08:28 PM »
 Is this the Chinese smart car copy, the Shuanghuan bubble...
Re: PN #127
« Reply #2 on: November 24, 2010, 10:27:08 PM »
It is Chinese, but not the Shuanghuan Noble
Re: PN #127
« Reply #3 on: November 30, 2010, 03:16:23 AM »
Re: PN #127
« Reply #4 on: December 08, 2010, 07:59:17 AM »
Professionals?
Offline del78
  • Puzzle Points 269
  • SiD
Re: PN #127
« Reply #5 on: January 05, 2011, 09:00:14 PM »
Sunmotor?
Re: PN #127
« Reply #6 on: January 05, 2011, 11:30:26 PM »
Nope
Re: PN #127
« Reply #7 on: January 06, 2011, 02:50:56 AM »
Another photo
Offline Oguerrerob
  • Country: ve
  • Puzzle Points 1475
  • Ver 2.0
Re: PN #127
« Reply #8 on: February 10, 2011, 12:24:46 PM »
electric car TS100000 by Shanghai Tesuo Trading Co., Ltd China
Specifications
Max range : 80km
Max speed: 90km
PEFORMANCE
Max range : 80km
Max speed: 90km
Ground clearance :170mm
DRIVE  SYSTEM
Gear box: 5 transmission (manual)
Drive way: Front-wheel drive
DIMENSIONS & WEIGHT
L*W*H: 3010mm  x1650mm  x1600mm
Wheel base: 1390mm /1390mm
Weight with batteries: 1200kg
SUSPENSION
Front: MacPherson
Rear: Dependent trailing arm type with cylindrical coil spring and dual-acting tube damper
BRAKES
Four Wheel Hydraulic
Front Disc/Rear Drum
Hand Lever Parking Brake
POWER SYSTEM
Motor: 6KW AC motor
Controller: DSP
Batteries: Six 12V Heavy Duty Deep-Cycle
Battery Charger: 110v/220v Automatic Charger
Charger time: 6-8hours
Brake light of the high position
Whole anticollision skeleton
Theft-proof remote control lock
Electronic reversing mirror
The top-grade electron combined  metre
Back air deflector board
Spare tire with iron rim
4 sound channel high-fidelity sounders
Colorful car body and interior decoration
Safety belt of the whole seat
Rear view mirror against blindness
Electronic doors and windows
Rear windshield with electric heat defrosting
Preposing and Postposition foglight
15 inches iron rim 195/50/R15
Radio &MP3/4
Rotatable draught of 360 degrees
Top-graded woolen seat
BODY&CHASSIS
Colors: Red with siliver  (other colors optional)
Frame: Whole anticollision
Seating: 2
Material: Metal
STEERING
Rack-and-Pinion Steering
TIRES & WHEELS
195/50/R15  Iron rims
OPTIONAL PartS( Chargeable)
Re: PN #127
« Reply #9 on: February 10, 2011, 12:26:52 PM »
It is a Chinese electric car, but the company which you mentioned only sells the car which is manufactured by another company
Offline Oguerrerob
  • Country: ve
  • Ver 2.0
Re: PN #127
« Reply #10 on: February 10, 2011, 12:41:11 PM »
I'll keep searching. Maybe if you lock it for me for 24h I could find it
Offline Oguerrerob
  • Country: ve
  • Ver 2.0
Re: PN #127
« Reply #11 on: February 10, 2011, 07:29:06 PM »
Mini Electric Car (AG-1) HCEV-AC60-V2ND by SHENZHEN GREENWHEEL ELECTRIC VEHICLE CO., LTD
Re: PN #127
« Reply #12 on: February 10, 2011, 09:12:05 PM »
And you did find it! Congratulations
