Author Topic: Solved - NEH 785: La Saetta - 1952  (Read 998 times)
« on: October 22, 2010, 10:41:55 AM »
If you know what this is spill the beans and if you're right you'll get 1 point!
Re: NEH 785
« Reply #1 on: November 03, 2010, 12:13:52 PM »
Time for a move up...
Re: NEH 785
« Reply #2 on: November 18, 2010, 11:22:37 AM »
...to the Pro's
Re: NEH 785
« Reply #3 on: November 18, 2010, 11:26:44 AM »
La Saetta by Testaguzza.
« Last Edit: November 18, 2010, 11:30:32 AM by Paul Jaray »
Re: NEH 785
« Reply #4 on: November 18, 2010, 11:44:51 AM »
Gino and Cesare Testaguzza introduced a fiberglass body of their own design and construction in 1952. This was a Chevy sedan-based prototype called "La Saetta" and was designed to fit American car chassis with 110-116-inch wheelbase and a removable hardtop.
After trying unsuccessfully to interest Detroit manufacturers they decided to go into production on their own and they set up a plant in Ogden, Michigan. Five bodies per day was the plan and it was available in turnkey form with Chevy running gear at $1800, or just the kit at $1000.
This car has not to be confused with the later prototype shown in 1955 by Electronic Motor Car Company in Salt Lake City, Utah, that was a La Saetta-bodied hybrid, called 'Turbo-Electric'.
Re: NEH 785
« Reply #5 on: November 18, 2010, 02:24:30 PM »
Now we know why they're called "The Professionals"!
Terrific reply PJ.
Shame it's only worth 1 measly point...
Re: Solved - NEH 785: La Saetta - 1952
« Reply #6 on: November 22, 2010, 10:48:26 AM »
More:
« Reply #7 on: November 01, 2011, 11:54:14 AM »
The “Electronic” is displayed in this press photo, which was taken in Salt Lake City, on June 23, 1955. The one page press release with it is filled with the usual pie in the sky claims that we won’t bore you with, but we will fill you in on the claimed details. F. B. Malouf, president of the “multi-million dollar” Electronic Motor Vehicle Corp. states the following about the car; It has a fiber-glass body of 45,000 psi tensile strength. It is driven by a “dual torque” motor which is powered by silver-zinc-peroxide batteries energized by a small turbine operated generator. The top speed is said to be in excess of 100mph.
The release goes on to state how two factories are already built and the new model is already in production with 400 targeted to be made in the first year. A third factory was also planned for Salt Lake City.
What we did find after some research is that this was an attempt at an early hybrid and it was called the La Saetta. It had a gasoline or diesel powered motor/generator turbine unit. We were not able to find any more information on this early idea before its time, but suspect that this may have been the only one built. Be sure to let us know if you can add any more to the story. The Old Motor photo.
« Last Edit: November 01, 2011, 11:58:53 AM by Ray B. »
