Author Topic: Friday Fun / Name That Bus #1745 Kaiser Permanente Articulated Intercity Bus  (Read 467 times)
If you haven't registered yet, you need to do so in order to reply with your answer.  You can do so by clicking here.
« Last Edit: October 17, 2010, 05:24:04 AM by Otto Puzzell »
Re: Friday Fun / Name That.....Bus? #1745
« Reply #1 on: October 08, 2010, 04:16:46 AM »
Is it in front of the Karnegie Hall?
« Reply #2 on: October 08, 2010, 04:18:17 AM »
Yes, after much kareening ;D
« Reply #3 on: October 15, 2010, 04:27:00 AM »
Next stop: Expertville!
Online pguillem
  • Puzzle Points 540
  • Designer
« Reply #4 on: October 15, 2010, 09:24:24 AM »
Kaiser 1946 Santa Fe Trailways
« Last Edit: October 16, 2010, 11:00:04 AM by pguillem »
« Reply #5 on: October 17, 2010, 05:23:15 AM »
While it was for a time painted in Santa Fe (railroad) livery, it was called the "Kaiser Permanente Articulated Intercity Bus"
Built in 1946 at Kaiser’s Permanente Metals Corporation plant near Los Altos, California, the three-axle, 60-foot bus featured true monocoque construction and used a 275hp supercharged six-cylinder Cummins diesel engine under the floor of the front section. The remainder of the under-floor space was used for the air-conditioning unit and for luggage storage, which helped lower the center of gravity – as did the use of aluminum for the lower portion of the body and magnesium for the uppe
The Karn Utz livery was but a figment of my imagination. :)
