Solved: 187. of All., Brooks Lakester
Started by Allemano, April 01, 2009, 05:33:58 AM
Allemano
Let them talk:
gilescooperuk
As it looks like it still has an outboard engine attached does the speedboat portion undock for water use?
Cars and er other photos
Allemano
Allemano
jotage21
Lakester, made by George Barris
Allemano
That's not the name I have for it!  :-\
jotage21
Lakester, by Brook Stevens
Allemano
#7
Brook Stevens is correct, but however "Lakester" is not mentioned. It's more a descriptive name that I've saved!
Maybe your sources will prove me wrong, but you have to confirm!
Locked for you for 24h
jotage21
Allemano
jotage21
Evinrude Lakester 1963
Allemano
I believe you're correct though my source states something else...! (something less)
Moved to the 'Solved' section!
porridgehead
Combination boat/dune buggy? So how do you launch this thing? Back it into the water and float the boat off, leaving the chassis to fend for itself as you go out for a spin?
I'm guessing that this was not meant for areas with salt water or, God forbid, tides.
Wouldn't work too well in Eastport, Maine. (20 foot tides)
Allemano
porridgehead
Two great ideas that go together like gin and plutonium!
Allemano
#15
I still can't see how it is steered on the road!  ??? Weight shift?  ;D
porridgehead
Yeah, well see, it's kinda like this.... ummm... was that in the original specification? I'm pretty sure nobody mentioned that it had to be steered on the street. Or dunes. And about powering the car portion via the outboard... well that's right out.
gilescooperuk
Thank god someone scrapped this and instead came up with the Aquada Sports Amphibian instead....
Carnut
sixtee5cuda
For some reason, there are a number of web sites calling this the "Evinrude Rooney Lakester".  No explanation of who "Rooney" was.
