Author Topic: Solved - NEH 106: Gustav Weinert's 'Flip-Car' - 1954 AKA Stolz or Stolzer  (Read 2163 times)
For 1 point, what's this?
« Last Edit: November 11, 2017, 11:48:29 AM by Wendax »
Offline Red Baron
  • Puzzle Points 0
Re: NEH 106
« Reply #1 on: November 28, 2009, 03:26:04 PM »
An automobile built by German mechanich Gustav Weinert:
Regards,Red Baron
« Last Edit: November 11, 2017, 11:49:09 AM by Wendax »
Re: NEH 106
« Reply #2 on: November 28, 2009, 06:55:27 PM »
1 more point for  you!
Re: Solved - NEH 106: Gustav Weinert's 'Flip-Car' - 1954
« Reply #3 on: November 29, 2009, 05:11:34 AM »
Actually this car is based on a Maico 400!
NEH 3039
« Reply #4 on: October 04, 2013, 07:41:10 AM »
Identify this car correctly for 1 point:
Re: NEH 3039
« Reply #5 on: October 11, 2013, 04:56:15 AM »
Offline luisps
  • Puzzle Points 408
Re: NEH 3039
« Reply #6 on: October 11, 2013, 07:23:47 AM »
This car appears in a web with the name of STOLZER, bud the same web had few years ago the name of STOLZ for it. Is a one of car made by the German Gustav Weinert and with that name can be considered  a repost of: http://www.autopuzzles.com/forum/index.php?topic=10155.0 In case of be asking for the STOLZER/STOLZ name needs to be merged and change he final name of the former post.
Re: NEH 3039
« Reply #7 on: October 11, 2013, 07:37:26 AM »
Ok, thanks for that.  I've merged it with a new title.
I coud find nothing on the'Net about "Stolzer" so I did wonder if that was right or not..
I've given you a point since you identified it correctly; no-one got a point for it last time since it was identified by the infamous Red Baron, which was a waste of a good puzzle really...
Here's a rear view and the unmodified puzzle photo:
« Last Edit: October 11, 2013, 07:39:50 AM by Carnut »
  • Puzzle Points 2376
« Reply #8 on: October 11, 2013, 07:40:42 AM »
The Weinert car is from 1954, so that it most probably only used the 400 cc engine of the Maico Taifun motorcycle. The Maico MC400 of Champion heritage appeared in 1955.
  • Puzzle Points 1189
Re: Solved - NEH 106: Gustav Weinert's 'Flip-Car' - 1954 AKA Stolz or Stolzer
« Reply #9 on: November 02, 2018, 12:46:38 PM »
It used a 400 cc Ilo motorcycle engine with 12.5 hp, max speed cca 85 km/h. Length: 2550 mm, width: 1500 mm, height: 1100 mm, wheelbase: 1450 mm. Weight: cca 320 kg
This article appeared in Auto und Maschine which later became Auto und Kraftrad magazine
