Author Topic: Whaddyacallit #412 - Ruston Lange's 1954 proposal for the Volvo PV 454  (Read 688 times)
Ever seen this ?
If you did, please respond below and let us know the make and model of the car posted here.
« Last Edit: November 27, 2010, 04:59:55 AM by Ray B. »
Re: Whaddyacallit #412
« Reply #1 on: September 01, 2009, 09:07:57 AM »
Mock-up for Volvo PV644 styling proposal?
« Reply #2 on: September 01, 2009, 10:25:42 AM »
You're almost right. But PV644 is wrong.
Locked for you 48 hours.
« Reply #3 on: September 02, 2009, 11:22:02 AM »
It's a 1954 proposal by Volvo in-house designer Ruston Lange to update the PV444 (think the suggested name was PV454) with this design inspired by a 1953 US Ford.
The PV444 was not updated until they made it into the PV544 in 1958, with a much more conservative restyle.
« Last Edit: September 03, 2009, 04:48:06 AM by Carnut »
« Reply #4 on: September 04, 2009, 10:33:38 AM »
You're right, and this is Ruston Lange's proposal. There were so many numbers that I don't know if this one was still called PV454. But it also had a specific number, not shared with any other proposal.
This number will be worth another point. Locked for you 48 hours
« Last Edit: September 05, 2009, 03:46:12 AM by Ray B. »
« Reply #5 on: September 07, 2009, 08:02:40 AM »
You do like to make it difficult!
Can't find much else out.
It was said to be 'similar to proposal #65 from around the same period' but not sure whether this is proposal #65 itself.  Probably not but can't find any other specific number for it.
« Reply #6 on: September 07, 2009, 09:01:29 AM »
Difficult maybe, but it makes your identification complete, gets you another point and makes an expert out of you.
From what I found it IS proposal #65 or Typ 65.
