Author Topic: Whaddyacallit #439 - 1948 Boardman Roadster based on a '47 Studebaker Commander  (Read 742 times)
Ever seen this ?
If you did, please respond below and let us know the "make and model" of the car posted here.
« Last Edit: November 27, 2010, 01:05:08 PM by Ray B. »
Re: Whaddyacallit #439
« Reply #1 on: October 26, 2009, 09:57:13 AM »
Expertise this.
Offline spider murphy
  • Puzzle Points 103
  • Valued Contributor
« Reply #2 on: October 26, 2009, 10:17:42 AM »
It's the Boardman 2-door Convertible, built by Boardman Motors from Augusta (Georgia - USA) in 1948.
« Reply #3 on: October 26, 2009, 10:25:57 AM »
I suppose you know what it is based on?
  • Puzzle Points 103
« Reply #4 on: October 26, 2009, 02:10:17 PM »
Yes I know, you mean the '47 Studebaker Commander Business Coupé.
Offline Joćo
  • Puzzle Points 881
« Reply #5 on: October 26, 2009, 03:13:57 PM »
Weird..I found another name for it!
« Reply #6 on: October 26, 2009, 05:46:53 PM »
Weird indeed. My source says is a Champion, not a Commander, but a 1947 Stude indeed, as it still obvious is. Slight mistake, and spider murphy deserves the point anyway. What name do you have, Joao?
Offline Joćo
  • Puzzle Points 881
« Reply #7 on: October 26, 2009, 05:50:18 PM »
1947 Studebaker Champion Custom Sportster by Harold Boardman ,that“s the name that I have.
« Reply #8 on: October 26, 2009, 06:08:50 PM »
Here's what I have on this:
Boardman 1948
Boardman Motors, Augusta, Ga.
When the 1947 Studebaker hit the streets its styling was sensational. A Georgia firm tried to produce and market a variation of the Commander Business coupe. They turned it into a roadster with cut down doors. Slight re-shaping was done to the rear deck.
Engine was the Studebaker Commander unit: Six-cylinder. L-head. Cast iron block, 226.2 cid, bore and stroke: 3-5/16x4-3/8 inches. Compression ratio: 6.5:1. brake hp:94 at 3600 rpm. Four main bearings. Solid valve lifters. Carburetor: BXOV-26 one-barrel.
Three-speed manual transmission.
Wheelbase:119 inches. Overall lenght: 204-1/8 inches. Tire size: 6.50x15
« Reply #9 on: October 26, 2009, 06:11:59 PM »
Me too. So, spider murphy, did Harold Boardman Jr; (you forgot the Jr.) run a business named Boardman Motors in Augusta, or did you made that up?
My source says he rebuilt the car with a few friends, which should make it purely a one-off. Then call it Custom Sporster or 2-door convertible, that doesn't make any difference since it's not a production model.
EDIT: I wrote this before seeing Paul Jaray answer, so it was a reply to Joao's post. Now, Paul has the same source than spider murphy, and I had the same as Joao. But both spider and Paul are more correct. The proof is that 119 inches was indeeed the wheelbase of the Commander (Champions rode on a 112 inches wheelbase). That settles it.
« Last Edit: October 26, 2009, 06:16:40 PM by Ray B. »
I took that info from Gunnell's Standard Catalog of American cars.
(but I have also that article where they say it was Champion)
... (but I have also that article where they say it was Champion)
I don't doubt that.
