Author Topic: ***Whaddyacallit #100*** SOLVED! Preston Tucker's proposed Carioca  (Read 1160 times)
Ever seen this ?
Thanks.
« Last Edit: January 23, 2021, 03:55:03 AM by Oguerrerob »
Re: ***Whaddyacallit #100***
« Reply #1 on: June 23, 2008, 10:21:58 AM »
Moved.
Offline jotage21
  • Puzzle Points 335
« Reply #2 on: June 23, 2008, 12:46:46 PM »
Tucker Carioca
Offline Tuckeroo
  • Puzzle Points 122
« Reply #3 on: June 23, 2008, 02:46:46 PM »
Speaking as Tuckeroo, I should point out that while Carioca is correct, in 1955 when Preston Tucker was trying to start up this venture in Brazil, he unfortunately no longer held the right to produce a car under his own last name.  The name "Tucker" and the rights to use it for automobile production was procured by a private investor when the company was liquidated by the court appointed trustees.  So technically it should just be the "proposed for 1956" Carioca.  Still, sour grapes on my part for not spotting this puzzle first.  :P
« Last Edit: June 23, 2008, 02:49:32 PM by Tuckeroo »
« Reply #4 on: June 24, 2008, 04:37:38 AM »
This is the Carioca indeed, and it's quite logical that a Brazilian found it.
But I think that Tuckeroo rightly deserves another point for correcting the name.
Offline Tuckeroo
  • Puzzle Points 122
Re: ***Whaddyacallit #100*** SOLVED! Preston Tucker's proposed Carioca
« Reply #5 on: June 24, 2008, 02:28:17 PM »
Awesome!  Thank you so much!  :)
