Author Topic: No 59 from Allan L Solved C1929 Maserati Tipo V4 "Sedici Cilindri"  (Read 1402 times)
  • Puzzle Points 414
Here's an unusual car for you.
Make, model, number of cylinders, engine configuration and anything else you think might interest someone!
« Last Edit: March 17, 2015, 06:08:39 AM by Allan L »
Offline ImpishGrin
  • Puzzle Points 303
  • Afficionado Anorak
Re: No 59 from Allan L
« Reply #1 on: November 20, 2008, 12:26:12 PM »
Some kind of 8C from Maserati?
  • Puzzle Points 414
« Reply #2 on: November 20, 2008, 12:52:32 PM »
If I say "yes" it will mislead you, but "no" is a bit too strong!
Keep on with your research in that area.
  • Puzzle Points 414
« Reply #3 on: November 23, 2008, 07:51:28 AM »
Time for an expert to finish this off!
Offline shamrock
  • Country: ie
  • Puzzle Points 0
« Reply #4 on: November 23, 2008, 06:05:24 PM »
alta ?
Offline neilshouse
  • Country: england
  • Puzzle Points 433
  • I want one!
« Reply #5 on: November 24, 2008, 04:24:33 AM »
This is the recreation of the C1929 Maserati Tipo V4 "Sedici Cilindri", built  by Anthony Hartley. It has a V16 engine.
  • Puzzle Points 414
« Reply #6 on: November 24, 2008, 04:41:44 AM »
Pretty well correct, that's the car and that's how the engine is described.
A voice from the back row would ask if a twin-crankshaft twin-bank engine should be called a V-16 ???
Offline neilshouse
  • Country: england
  • Puzzle Points 433
  • I want one!
Re: No 59 from Allan L Solved C1929 Maserati Tipo V4 "Sedici Cilindri"
« Reply #7 on: November 24, 2008, 04:45:35 AM »
I think both cranks run in the same crankcase and are geared together so it is nearly a V16.
  • Puzzle Points 414
« Reply #8 on: November 24, 2008, 05:01:53 AM »
Certainly, and it's not easy to come up with an alternative description.
For the benefit of the others, this is what we're on about
« Last Edit: March 17, 2015, 06:09:53 AM by Allan L »
« Reply #9 on: November 24, 2008, 05:23:58 PM »
Surely that makes it a U-16?   ;)
  • Puzzle Points 414
« Reply #10 on: November 25, 2008, 03:17:44 AM »
Yes, now you remind me I have heard that description. ;)
